I would not be concerned, The thin shims are designed to be added or subtracted to adjust the preload on the knuckle. The Bottom shim(s) is what does most of the centering.
Out of curiosity, how thick was the 'thin' shim that you removed?
We're the shims the same between the drivers and passengers side? Only reason I ask is because when I did mine, the shims that I removed were the same combination left and right and when I measured with the sst, they were both incorrectly shimmed (significantly) and should not have been the same left and right. Someone likely did the job sometime between when Toyota did it and I did it.
I meant to ask you, where to buy the Marlins? I checked the usual vendors, don't see Marlins listed for my year.I guess you find out when the back side gets covered in gear oil again. If you used Marlins seals you may be OK.
Marlin Crawler's website.
I'm also curious about the "thin" shim you removed. I always try to be as accurate as possible when doing technical work, however, if it's the 0.008 shim you removed to achieve the pre-load that is easily within the margin of error when the average person is measuring the distance between the scribe marks on the centering tool.
