Thanks in advance, I know the answers are here, it's just been years since I read the thread
My rig is a 62/63 but the motor wasn't original (or so I heard)
I believe the donor motor was a 67
I'm also wondering if the heads will swap, as that might be the cheapest fix out of the mess I'm in.
Does anybody know the compatibility of the two blocks, and if this is a bad idea?
Thanks-Josh
the oldest block is f17093720405 is that the old block?
What is the F engine number on that one?
Awesome. He described my rig to a t (except mine is red/white).Your truck is 4 vin numbers away from one that @Old Red posted up in the registry thread... Post #92
Link>>> https://forum.ih8mud.com/threads/40-series-registry.771909/page-5
That would be nice. It ran well before it happened. It just seemd too sudden. I assumed I had bent a rod or something, but when I popped the vc all the lifters looked to be doing exactly as they should. That's when I assumed I had a hole in my piston (or something else catastrophic).Maybe you even just blew out the gasket between 5&6
How were the #rs in the other cylinders? You remember?
