It is my opinion that if the wiper seals in our Birfields were better at containing a less viscous lubricant inside the Birfs, that using a heavy gear oil (molybdenum fortified) would work just as well, if not substantially better than using grease. Once again, this is just my OPINION but here is why I feel this way:
I used to own a 1976 GMC 3/4 ton 2WD pickup with the Corporate 14 bolt rear axle (and a 454) (this axle is known for being brutally strong). This axle is a full floating rear axle design and the wheel bearings are lubricated by the gear oil in the axle (not grease). Gear oil would travel from the diffrential housing, through the axle tubes and into the bearings at the end of the tubes. This design worked very well and I never had ANY wheel bearing problems. My father ordered this truck from the factory and it has been in the family since new (he never had any issues either).
One of the benefits to this design (in my opinion) is that the bearings have access to MUCH more lubricant (and the lubricant circulates regularly) and thus the bearings last a VERY long time. When we pack bearings with grease, how much of the grease ACTUALLY circulates through the bearing on a regular basis? My experience is that only a small portion of the grease that we put into the bearing and the immediate area around it actually circulate through the bearing. If the corporate 14 axle design used a closed compartment design and the bearings were lubricated with grease, I think the bearing life would be much shorter.
The front Birfield design in our LC's doesnt hold gear oil well, it will leak (sometimes A LOT) because the felt gasket is not designed to hold less viscous lubricants. So it is my guess that Toyota knew that if gear oil was used in the Birf housing, the oil would leak out and many Birf joints would fail which would be a warranty nightmare (they already have enough of those). Plus, even if the failure didn't happen quickly, there would be many crabby LC owners complaining about oil leaks on their garage floors. Designing a birf that could hold gear oil would probably be difficult.
Another concept that makes me think gear oil would be better for the Birf, is centripetal force. As the Birf joint spins, centripetal force will attempt to move the grease OUT of the joint, especially the center section where the balls are. If we are instructed by the service manual to put a thick grease (NLGI 2) in the Birf housing, and this grease moves out of the KEY part of the joint, how does the grease get back INTO the joint?? If your grease maintains its viscosity, it will NOT go back into the joint easily. Gear oil on the other hand will go right back into the joint whenever the joint slows down or stops spinning. Gear oil would also be nice because it would flow out of the Birf housing and into the wheel bearings, keeping them nicely lubricated.
It is my opinion that many of our Birfield joints fail because the grease leaves the joint and doesn't get back in.
So my guess is that Toyota recommends using grease because it doesn't leak out quite as easily as gear oil would, because vehicle owners wouldn't check (and fill) the gear oil frequently enough, AND because it provides sufficient lubrication to allow the joint to last for an acceptable amount of time.
In my opinion, gear oil should be fine for the bearings and the joints (especially if the birf housing were filled to 3/4 full). I don't think grease is the best solution for the birfield joints, I think they would last longer with gear lube.
I know there are many advocates of using the specified grease and I am not saying that you are wrong to use grease (heck, I just bought 5 tubes of Amsoil synthetic moly for the Birfs) . I think grease is an excellent lubricant, I just have to wonder HOW the grease gets back into the joint after high speed rotation (I realize some greases are thick enough to resist being slung out of the joint). If there were a good way to make sure the grease didn't work its way out of the joint, everything would be perfect!
Maybe we need a Birf Boot?
