First post on Mud
Great thread so far, can't wait to see it running!
As far as the EGR goes, by circulating exhaust into the air-fuel mixture it helps to reduce combustion temps, preventing NoX (nitric oxides) - the stuff that makes smog look brown. The catalytic converters don't reduce this type of emission, as they mostly reduce hydrocarbons through catalysis (chemical conversion). My '96 4runner didn't come with an EGR system and still passes California smog, so you should be ok without it. Besides lower emissions, by reducing combustion temps it also helps with pre-detonation/knock (lean afr, high compression, etc...), although probably not as much as high octane fuel or water/meth injection.
Best of luck with the rest of the build!
