- Thread starter
- #61
UPDATE
It's been over a week. Took a weekend off to canoe down a river, catch some smallmouth, and drink around a campfire.
Sunday, 9/23:
I cleaned out the block from below with oil pump removed. NO detergent, just clean rags, rub to make "sand falling" noise, went from front to back 2 or 3 times until no more "sand falling noise".
Put on new side cover gasket
Cleaned-regasketted & installed oil cooler
Installed distributor & tore up O-ring pretty bad - new one coming.
Installed 5 of 6 pistons. When went to install #2, the nut wouldn't turn all the way up & down the stud on the rod. I wonder if this somehow attributed to the #2 piston failure? Ordered new studs from Cdan.
Lastly, I poured oil on top of the pistons in the cylinders to see if any leaked out. NONE! Hopefully this is a sign that my compression will be good.
Today 10/2: Started looking at posts about the vacuum system and want to clean it out while I wait on parts. A lot of frickin' ackronyms VSV, EGR, etc. Anyhow, I looked at the hard, metal tubes. Took brake cleaner & straw and sprayed threw all the tubes. One is clogged bad on both sides where it hits the hose. How do you unclog these things? I'll keep searching. I believe I'm going to try a small drill & see if I can get clean it out. It appears to be independent of other tubes, so I may find a similar diameter tube & replace it using hoses at the bends. I heard of "jon held" method of cleaning these, but couldn't find it.
Tomorrow 10/3: I have a bad head cold, so am staying home from work tomorrow (other than a meeting). I'm going to get oil pan and valve cover cleaned off & ready for reassembly. I should be totally ready for reassembly this weekend.
That's the poop!
Oh yeah, radiator was bad, so I bought a $200 lifetime warrantee, all aluminum one from buyaradiator.com. I know, "you get what you pay for" but an OEM is 2+ that cost.
And fellow MUDder offered to come by Sunday to help. He's got a FJ55 & doing major work on it. It'll be nice to meet him.
Sunday, 9/23:
That's the poop!
