I actually had two "hot" leads coming off of the converter, one to the memory of the headunit and one to the relay. Then from the relay I went to the 12 volt fuse block. That way the entire fuse block was switching off with the ignition via the relay. Even though my converter is always on the only drain it sees with the ignition off is the memory to the headunit.
