- Thread starter
- #21
yeah no promblem, once all the bits have arrived ill document it all. That thing is pretty easy to wire and setup. the temp probe can be zip tied to the original toyota probe in front of the evaporator. The power supply will come from the original amplifier power wire, same goes for ground. the original compressor clutch circuit then runs through the onboard relay K0 and K1 terminals, through the hi/low pressure switch, and down to the compressor clutch. All wiring required is there so it will be easy, then its a matter of setting the switch off temp. Ill also wire in a NC relay on the compressor clutch wire which will be connected to the starting circuit(the wire is also there at the amplifier) to make sure a/c is off whilst im cranking
