- Thread starter
- #41
37s work great with 5.25" of lift (4" + 30mm spacer). I haven't flexed it out fully, but don't think it will rub. Will know more this weekend when it is on the trail.How are the 37's working out with the 4" Slee lift and 30mm spacers?
Have you had a chance to see if they rub at full articulation?
Would you go with the 6" Slee lift if you started over again?
What would you change with your current setup?
Thanks
Ron
I think the 6" is too much for our trucks. Especially in the rear where the 4" is actually giving me 5.25" unloaded. I have heard of many who have swapped from 6" to 4" coils as it was too tippy / top heavy.
Also, just having springs and no rubber spacer will probably ride much rougher - the 30mm spacer gives the padding needed to take the edge off the pot holes.
So far I wouldn't change a thing.
