Bogo
FOOF
My alternator is starting to squeal. It doesn't sound like a stuck pig yet, but now is the time to fix it. I'm betting the front bearing is going out. No matter what I do, I will rebuild the one I have. I'm trying to determine if I go forward with an alternator upgrade now or later, and what is likely the best candidate to go with. I'm leaning toward upgrading now as it will allow adding an isolated second battery by summer.
What high output alternators do you have experience with and what do you think of them after having used them for awhile?
My main use will be recharging a battery bank that will be powering my laptop, lighting, camera battery recharging, running a refrigerator, etc..
The alternator will be attached to a 3VZE in a '95 4Runner.
Sofar the two possibilities with the greatest apeal to me are: http://www.off-road.com/trucks-4x4/tech/100-amp-alt-upgrade-18551.html which uses a 1991 Toyota MR2 100 Amp alternator, and High Output Alternators For Toyota Applications which uses a GM 140 Amp to 250 Amp alternators. They both seam to have minimal modifications needed for alternators designed for their output Amps.
Edit: Thread title should read "3.0 High Output Alternator choices and Experiences?"
