I think it depends heavily on how it was used. If you are towing heavy in hot climates your clutch gets orders of magnitude more abuse than someone that never tows and lives in Canada.At the risk of hijacking the radiator thread, what is the average mileage we should expect to get out of the fan clutch? If I'm ~110k and doing the radiator, just do the fan clutch anyway? Or leave it?
Depending on how long you can have the rig down, you may consider tossing new brushes into the alternator.Had to take a break mid-job.
A couple thoughts:
• get a cheap set of Amazon hose clamp pliers and some plastic hose pinch tools.
• Long extensions (and a telescoping magnet tool, really) are needed for the lower radiator bolts.
I’m about to replace all these things (plus hoses) now that the radiator is out:
The fluid looks pretty clean, although I’m not sure what it is supposed to look like at 176k miles. If you haven’t cleaned the front of your radiator in a while, you may want to.
This belt looks really good. And aftermarket. The upper and lower hoses look new, too. We’ve put 27k miles on this since buying it with 149k miles. Looks like maybe new fluid, hoses, and belt were installed by a local shop not too long ago.
Yeah, lack of parts got me on that one this time.Depending on how long you can have the rig down, you may consider tossing new brushes into the alternator.
With the radiator out it’s about an hour of extra work, I did it today. I plan to do a write up of that job soon.. your problem is the part is rare and usually needs special ordered.
I'd say you have quite a while, but it's good you're looking into getting it sorted.2013 LC200, 49500km- how bad is it? I am based in NZ and decided to take it into the local dealership. They asked me to send them some photos and they will contact Toyota. My expectations are quite low, but lets see what they say.
View attachment 3619171View attachment 3619172
4.6 Petrol, JDM import. CheersI'd say you have quite a while, but it's good you're looking into getting it sorted.
Out of curiosity is this diesel or petrol?
