tmxmotorsports
Correct wiring comes from the driver side.Pretty sure that connector is EC1 and should be routed to the drivers side and connect to the main engine harness.
When you pull the heartercore...will you document this? I would love to see how to pull the dash etc. I know there are others who have done it, but you explain it well.Took the LC for its first trip out of town. I was sure nervous! Went to the Wichita mountains. Didn’t do much off-road. Barely some gravel. Wasn’t the point of this trip. Wanted to cruise at Highway speeds and monitor temps. Temp never moved from dead center. It was also as perfect of a day. 40-60 degrees overcast. Found a few small issues. Some cheap wire loom melted near exhaust. Speedo is slow by 6 mph. Heater core leaks. But what a feeling of starting it up the next morning. I was dreading it. No cell service! Fired right up.
So more info on what I’ve run into.
The ac was the same size. I don’t think my Hester core was salvageable. I called a master plumber , he said he can braze on the the tube I need to use and get off the one that isn’t correct. I’ll keep ya posted.
