Even if he didnt isnt the shutoff butterfly always in the open pos and only shuts on vacc??
No im not saying that at all, was actually asking a question..see above question marks. To me the name vacuum shutoff means shut once vacuum is applied. does it have anything to do with the engine starting? Which is actually what he wants it to do. Again, asking
I know theres a stop lever. he wants to start the motor not stop it. Shutting off is easyAll I am staying is make sure your vacuum hoses are on correctly and it shuts down and the butterfly is closed. All that stops these 12ht's is that butterfly. The butterfly will stay closed as long as there is a good vacuum seal.
PS. Niffa, There is a mechanical stop lever on the IP that you can push forward to stop the engine, its spring loaded so it will return to the run position. I have seen owners put a choke cable on the lever to cut the engine this way if they don't connect the VSV.
PSS. When are you going to try and start the engine?
Good point. Im going to get the fuel line above the pump, and put it in a gallon of fuel, then have my friend turn it over. The pump should be able to suck it straight down without a problem. Once its going, Ill let it idle for a bit, shut it off, and hook it up to the real fuel system.Itll sound horrible till it fires up completely. Iv ran mine dry accidently on an extremely steep hill..that was interesting.
Get as much diesel into it as poss and turn her over
Easier solution: go get a new primer pump.
Any Bosch or Denso diesel shop should have a handful on the shelf, and the last one I bought was maybe $30.
Dan
Pretty high-tech huh??Like your throttle cable adaption?
