My 100 series didn’t start the other morning so I took the upper intake hose off and sprayed in some starting fluid and it wanted to turn over. So I disconnected the fuel line going into the fuel filter and when turned over no fuel came out. I had this problem about four months ago and replaced the fuel pump and it worked great. I took out the hanging rack again and nothing was wrong, then I kinda moved it around and put it back in to see if it would work; nothing. So then I tested the wiring harness that is on the fuel pump lid and using a multimeter and it has no power and the resistance reading is null. And continuity reads like 462 ohms. The only thing left is the relay fuse; replaced the 20amp already. Any suggestions on what it could be? Thanks
