I like your signature!!
Changing the fuel filters is an easy no-brainer, depending on what carburetor you have there may be a screen that's plugs there also. Does this engine have the mechanical fuel pump on the lower passenger side or is it an electric fuel pump?
There may be another fuel filter inline before the fuel pump, look along the passenger side framerail. Follow the rubber line down the frame until it attaches to the hardline on the frame. Also remove the fitting on the carb fuel inlet that the rubber line is attached to and check for a debris screen inside it. The fuel pump is not hard to change-it is held in place with two bolts.
HTH,
Will
Do I understand correctly that a rubber fuel line runs inside the frame rail all the way back to the fuel tank? Originally there would be metal fuel lines (hard line) attached to the inside of the frame from the rear of the engine compartment to under the passenger seat. Then a rubber line up through the floor to the fuel tank. On my 69FST junkyard recovery truck the metal lines were rusted/trashed so I ran the rubber line inside an old garden hose to protect it from chaffing and then threaded it through the frame to the front. I recommend adding another fuel filter inline before the fuel pump to keep trash out of the fuel pump.Yeah the line goes into the frame rail, then comes back out by the passenger seat and goes up into the tank. Doesn't look like there is another filter.
