Hi Guys,
I thought I would start this thread here and possible have it mirrored on the expedition/challenge/rally page later as this is a performance issue.
I am going to be adding a turbo to my truck shortly and have been doing a bit of research. So far I have heard a few different things about turbos and would like to see what everyone here thinks.
A junk yard turbo is not an option for me as I don't like to cobble things together (ok, maybe sometimes if I have to), I'd rather use what has been designed - or best suited for my engine.
So, a Mapped Turbo seems to be the best route for my application - My application is add more power at a little lower rpm than say the stock 1HDT turbo that I think starts producing boost at about 1800 rpm and carries it up throught to 3500 rpm. We all know that we don't use these engines int eh 3500 rpm range - I rarely peak 3000 on mine. So it would be nice to use a turbo that is useful from a lower rpm - say 1400 or 1600 and up to about 2800-3000 rpm.
So this is what has been suggested to me so far:
http://www.turbobygarrett.com/turbobygarrett/catelog/Turbochargers/GT25/GT2554R_471171_3.htm
GT2554R - 471171- 3
* Ball bearing
* Oil & Water-cooled bearing system
* Smallest ball-bearing turbocharger
* Internally wastegated turbine housing
* T25 turbine inlet flange
* Great size for applications w/ packaging constraints
* Ideal for smaller displacement engines making up to 270 hp
GT2554R COMPRESSOR TURBINE
Turbo CHRA
471171-3 446179-24
Wh Dia Trim A/R Ind Exd 42.0mm 54.3mm 60 0.80
Wh Dia Trim A/R Type 53.0mm 62 0.64 Wastegated
AND:
GT2860RS - 739548 - 1
http://www.turbobygarrett.com/turbobygarrett/catelog/Turbochargers/GT28/GT2860RS_739548_1.htm
* Ball bearing
* Upgrade turbocharger for GT2554R (471171-3) and GT2560R (466541-1); turbine housing flanges are outline interchangable
* Ideal for smaller displacement engines making up to 36 0 hp
* Turbine Housing option available
GT2860RS-The Disco Potato COMPRESSOR TURBINE
Turbo CHRA
739548-1 446179-66
Wh Dia Trim A/R Ind Exd 47.2mm 60.0mm 62 0.60
Wh Dia Trim A/R Type 53.8mm 76 0.86 Wastegated
TURBINE HOUSING OPTION
Part Number
430609-230 Wh Dia Trim A/R Type - - 0.64 Wastegated
Turbo CHRA
739548-5 446179-66
Wh Dia Trim A/R Type 53.8mm 76 0.64 Wastegated
Part Number
430609-231 Wh Dia Trim A/R Type 53.8mm 76 0.86 Wastegated
I am told that the GT28 is the direct replacement for what is on the 1HDT now, and, the garrett site says the GT28 is a replacement for the GT255 (according to garrett site), so in order to get the same type of turbo that produces boost through a lower rpm range it seems that either the GT28 can be used with a smaller exhaust section or use the GT25 with the larger exhaust section - but boost maxes out quicker in the rpm range.
GT2554R - 471171- 3
* Ball bearing
Turbo CHRA
471171-3 446179-24
AND:
* Ball bearing
Turbo CHRA
739548-1 446179-66
Part Number
Turbo CHRA
739548-5 446179-66
Part Number
