I had a small leak coming from what i believe is an o-ring so i had my local shop change the o-ring and change the fluid. he put in power steering fluid instead of the recommended ATF dextron III. is this ok or should i insist he drain and re-fill with the proper fluid? ...he said power steering fluid is very similar and there aren't any noises coming from the system.
Thanks.
Thanks.
