LinkBack (28) Thread Tools Display Modes
Old 01-22-07, 07:15 AM   28 links from elsewhere to this Post. Click to view. #1 (permalink)
THC
Trollhole's Avatar
Garage
Buying a land Cruiser
Good article.
http://home.mchsi.com/~gregoverton/Buy.html
Buying a Land Cruiser
BAD CRUISER
GOOD CRUISER
The collective knowledge (and opinions) of many fine Land Cruiser enthusiasts.
This page is intended to help educate a new Land Cruiser buyer although any Land Cruiser lover should find some value here. This article is biased towards 40 series Land Cruisers, although it can be applied any model. Also, parts of this may sound a little like a sermon since for many, Land Cruiser ownership goes beyond possessing a vehicle and well into the realm of obsession. Are YOU willing to make a sacrifice for your Land Cruiser?
Furthermore, this article should be required reading for the new Land Cruiser owner. Running through the pre buy checklist will help you find potential
problems in your new truck, and see what maintenance needs to be done.
So you want to buy a Land Cruiser. First, some words of warning. If you're looking at a 40 series, the vehicle will have been produced before 1984. It was built as an off road vehicle and as a result has probably taken more of a beating than a car of a similar vintage. It will definitely require more upkeep than a new vehicle.
Land Cruisers are not always 100% Toyota by this day and age. I prefer the more stock variety but many people will offer Land Cruisers with V8's conversions and/or custom transmissions like the SM420 etc. I'm not saying it's bad, it's just not stock. You need to decide what YOU want in your Land Cruiser and how much you want to spend for it. Obviously the lower miles the better but beware that if the seller has no documentation to substantiate the miles, what you see is what you get. A Land Cruiser with 45,000 to 70,000 original miles will not have a brake pedal showing metal through the side of the rubber pad and a rubber floor mat with a hole worn through it where the heel of the drivers foot sits. It's very easy to swap the instrument cluster or roll back the miles so dated service receipts with mileage are big plus.
Talk to the seller on the phone or in person and find out how long they've had the vehicle, get some history and details on their description (i.e. "your ad said 'some rust', where is it and how extensive is it?"). Ask about maintenance records. One important question is "Why are you selling it?". If it's about to die for some reason, has been nickel and diming them to death, you may want to stay away. The best kind of answer is that they need to sell it to fund their other Land Cruiser projects, and/or they just don't drive it much any more, can't afford the mileage, that sort of thing. Many old Cruisers spent a good deal of their lives being towed behind a motor home or sitting around waiting for the next hunting or fishing trip. People get older and want something more comfortable. Check out this LIST OF QUESTIONS you can use as a starting point.
With all Land Cruisers, newer is definitely better in many areas. Unlike the Jeeps whose "quality" varied widely from year to year until Chrysler "neutered" them all and Land Rovers where some Series are shunned because their headlights are in the wrong place, Toyota was continually improving the Land Cruiser. Check the production timelines in the FAQ to determine which features you can live without and hence how old you're willing to go. The only exception to this rule is if you're living under a fascist regime such as Kalifornia where ancient frames are prized for their smog exempt status.
If your looking at a "restored" Land Cruiser's, you will find that the word "restored" has many meanings. It can mean some bondo and paint or a complete "frame off" restoration or anything in between! You might want to take a magnet along and see how much of the truck is still metal.
Usually long before someone decides to sell a Cruiser, they decide that they should stop pouring money into it. Therefore, shortly after you purchase your truck you can expect to have to dump a whole lot of money into it to fix little things the previous owner couldn't be bothered to do. This can be VERY discouraging. Don't worry. Once you get your truck into a roadworthy state, it will remain there for quite some time. When I first got my truck, the fuel gauge didn't work, most of the knobs were missing, the headlights had a nasty habit of turning off instead of switching to high beam, none of the interior or signal lights worked, the u-bolt plates were cracked, the shackle pins were about to rip out of the shackle plates, the rear tub was basically gone, along with the bottom 2" of the hard top and rear doors.
Older Land Cruisers (Anything other than a 60 or 80) don't make great daily drivers. They're loud, they suffer from a relatively harsh ride and vague on road handling, and the gas ones get lousy fuel economy. Thanks to brick like aerodynamics, side winds quickly become tail-winds. You don't want to do a long commute in an FJ40.
Anyway, that said, there are some requirements that I believe a Land Cruiser owner should meet. They need to have a steady income. I bought my Cruiser while I was in college and wound up having to take a couple of years off to work to be able to fix it up. If you're a starving student, you're probably better off with a mini truck. Parts are cheaper, and there's a whole lot more of them so they're more "disposable"
If you've got a significant other, your relationship has to be up to the stresses imposed by the new arrival. It may take a long time for your spouse to adjust to being a "Land Cruiser widow" If a Land Cruiser is brought into a weak relationship, there's always the chance you won't get to keep the house then you'd be without a garage to work in.
Actually, a garage is pretty much required. Lying out in the street is hazardous and people tend to walk off with tools they find lying on the sidewalk.
I also firmly believe that it's a good thing to learn to work on your Cruiser. If you have a professional mechanic attend to all you maintenance, you'll be out of luck when something goes wrong miles from the nearest gas station
So you've warned anyone that cares about you that their only contact with you may be standing in the garage yelling at the underside of your truck. You're mentally prepared to become the caretaker of a disappearing breed. Time to go shopping.
You should start scanning the local classified ads, the internet, truck traders for a couple of months before you actually begin to shop in earnest. That way, you can begin to check out the market. In certain parts of the U.S., you may not see many Cruisers. You will learn that FJ40 prices range from a few hundred bucks to tens of thousands.
When the time comes to go look at Land Cruiser spend a good 15-20 minutes of "quality time" crawling around underneath. Bring a flashlight so you can get a real good idea of (1) where the rust is (2) where the leaks are and (3) what kind of work has been done to it. Then spend another 20 minutes or so poking around under the hood, looking for what's stock and what's not, evidence of maintenance, color of oil, mixing of engine components from different years, etc. Pay special attention to the zerks on the tie rod ends and u-joints. Have they seen any grease this decade? By now you may have found hidden rust, bad leaks, lack of maintenance and shoddy repairs. Hack wiring jobs, botched welds and lots of non stock bits and pieces or perhaps all is going well! If you take it for a test drive, obviously listen for how it cranks over, how quick it catches, etc. Brakes, steering, shifting and engine strength and sound should all be evaluated. Does everything work, from the turn signals to the door locks to the windshield wipers. Test the 4WD, does it go in and out smoothly?
The things you should watch for can be grouped into several categories.
Engine
Check to see that it is cold, then if it's at all cool outside you will likely have to pull the choke, turn the key and giver her a little gas. She should start right up and hopefully there will not be a huge cloud of smoke behind her. Smell for exhaust fumes in the Cruiser, I've heard that the intake manifold tends to crack if the truck has been overheated and the exhaust manifold often need attention. It may have an exhaust header on it so look it over and check the condition. It's a real good idea to check the compression on each cylinder. 150psi would be perfect but I understand that 130psi or above is acceptable. The cylinders should be within 10% or so of each other. Check for coolant leaks from the hoses, water pump, and radiator. Next check for oil leaks from around the push rod inspection plate that the blow-by tube comes from, Rear main, oil pan, etc. It's very common to have some degree of oil leaking out of an FJ40 so no leaks is a great sign. Pull the spark plugs and check them for oil fouling. If they're coated, oil is getting into the cylinder past the rings and valve guides.
Diesel Engine
When the engine is fired up, watch how quickly the oil pressure builds. If the idle is high (the engine feels smooth instead of causing the whole truck to shake) There's probably either a hole in the diaphragm or the vacuum lines that go to it. Both are relatively cheap and easy to replace provided you buy Nippondenso and not Toyota parts. You can test a diaphragm by pulling off the top end of the "clear" vacuum hose that goes to the rearmost nipple on the injection pump and blowing into it. If you can build pressure, the diaphragm is still good.
It is normal for a cold diesel to blow a little white smoke at start-up. Black smoke usually means that the injectors need service, white smoke indicates under injection of diesel (probably due to a perforated diaphragm), and blue smoke shows that oil heavier than diesel is burning (Ohh ohh!) When the truck is running, check for excessive exhaust coming out of the blow-by tube. If the truck has a
noticeable miss as it warms up, one of the glow plugs is shot. They have to be replaced as a set. The amount of blow-by will indicate the amount of wear in the engine.
Cooling System
With the engine COMPLETELY cold, remove the rad cap and check the coolant level. If you can' actually see any coolant in the rad, there's probably a leak. If a B/H series diesel is overheated or run with inadequate coolant, the heads are prone to cracking. Carefully look at the radiator. Usually leaks will show up as whitish stains. When you return from a test drive, mist the rad with water. If all the water evaporates then the tubes aren't plugged. If there are areas where the water evaporates and others where it doesn't [cold spots, usually vertical sections of the rad] then the rad needs to be serviced [power flushed or rodded-out]. You can also check for cold spots by using your hand but there is often not a lot of space between the grille and the rad --> and you could burn your hand. Be careful.
Electrical
In both gas and diesel Cruisers, check the alternator for excessive play. A brand new one is worth a small fortune. Rebuilt 12V ones are difficult to find and 24V ones are virtually impossible. If a diesel alternator with a vacuum pump on the back shows any signs of oil leakage, it's probably shot.
If you find that there are accessories (radio etc. attached to only one battery of a 24V diesel, you can expect to replace the battery shortly. Drawing 12V off one of the battery loads them unequally leading to undercharging of one and overcharging of the other.
In 1974 and up 40 series, a dead bulb, bad ground, or wiring problem in a turn signal will result in the indicator light in the dash sticking "on"
In 60 and 70 series the same type of problem will show up as the indicator light flashing "double time"
Transmission/Transfer
Check for leaks in all the gaskets and seals. Chances are, if a seal is leaking, the bearing behind it is shot. Ask the owner what kind of lubricant they're using. Synthetic gear oil will often manage to seep past a seal that's good enough for regular oil. If a seal is weeping synthetic gear oil, chances are it's on its way out anyway.
Check for lateral play in the output yokes from the transfer case. Movement indicates bearings that are in need of replacement. If the movement is greater than 1/8" chances are the gears themselves have been damaged once that occurs, the transfer case gets expensive to re-build.
If a 40 series has been lifted more than 2", check to make sure that the notch in the skid plate the front drive shaft passes through has been enlarged. Otherwise, the rearmost yoke on the front driveshaft will bang on the plate causing the bearings in the transfer case to fail.
With the truck parked on a level surface, take out the transmission fill plug. If gear oil pours out of the plug, the seal between the transfer case and transmission is probably shot. This is a cheap part, but replacing it pretty much requires pulling the transfer and transmission. I also believe that when this seal goes, it's not a bad idea to rebuild the transfer anyway. It is usually the first internal problem that develops, and rebuilding the case when it goes ensures that all the gears will still be in good shape.
A leak from the rear output flange of the transfer usually results in destroyed parking brake shoes in pre 1981 transfer cases.
When test-driving the truck, feel how smoothly the truck shifts. It is normal for four and five speed transmissions to be a little balky when they're cold. The H55F 5 speed tends to be worse in this respect. If the transmission is difficult to shift when warm, chances are the synchros are shot.
Transmissions/transfer cases popping out of gear is a desperate cry for a rebuild. Left for any length of time, it will lead to severe gear/shift collar damage.
Trollhole's Crazy Forum
Marshall
Upstate Cruisers
Old North State Cruisers
TLCA
RIP Andrew Farmer
Originally Posted by grant5127 View Post
Having a motor that doesn't have enough power to pull a sick whore off the piss pot would be hard to ignore........
Old 01-22-07, 07:15 AM   #2 (permalink)
THC
Trollhole's Avatar
Garage
Driveshafts
Check for play in the universal joints. Although a worn joint is cheap to fix, if the truck has been driven with the excessive vibration of a failed joint for any length of time, the transfer case and pinion bearings can suffer. Dents in the shafts can also cause vibrations and premature failure. Grab the shafts on either side of the slip joint and try to rotate each side in the opposite direction. If there's movement, or worse yet a "clicking" the slip joint splines are worn and will need to be replaced. Check that the universal joints and slip joints have been greased, but NOT just prior to your arrival. (There should be SOME dirt stuck to any traces of grease on the zerk-fittings or around the joints)
Grab the driveshaft on either side of the slip joint and try to rotate the two halves relative to each other. Any movement indicates that the splines in the slip joint are shot and either the driveshaft must be cut and the splines replaced, or the whole driveshaft must be replaced.
Rear Axle
Check the pinion flange for excessive play. Usually slop here will result in an a destroyed ring and pinion.
While inspecting the brakes, check for any signs of gear oil on the backing plates or brake shoes. Gear oil that has leaked past the seal at the outboard end of the axle tube will saturate the brake shoes and destroy them.
It is rare for a Cruiser to experience wheel bearing failure unless they've REALLY been abused.
Front axle
The above rules for checking the pinion bearings apply along with some potential problems for the steering knuckles. Check that there is a thin coating of grease covering the knuckle balls from top to bottom. Accumulations of crud on the knuckle balls can indicate one of two things. Grease indicates that the knuckle seals are shot. Gear oil indicates that the seal inside the axle tube. Either problem requires complete disassembly of the knuckles. If the balls are dry, they've been run improperly lubricated for quite a while and at least the upper knuckle bearings will be destroyed. If the tire can be grabbed by the top and rocked back and forth, either the wheel bearing is loose, or the knuckle bearings are shot. Get someone else to try and rock the wheel and watch if it's moving relative to the knuckle or if the knuckle is moving relative to the axle tube. Quite often if the wheel bearings are loose, they are simply in need of re-packing and adjustment.
Steering
In manual steering equipped Cruisers, check for gear oil in the steering box by removing the breather vent located on the top. If there is none, the pitman arm seal has failed and the bearings are probably almost gone. If there is grease in the steering box, the seal has failed, and the owner has at least tried to extend the life of the steering box. It may be salvageable, but pulling the pitman arm to replace the seal will require a very stout puller and possibly a little heat from an oxy-acetelyne torch.
Have someone rock the steering wheel back and forth through a 90 degree arc while you inspect the steering box and center arm (on 40's-55's) The center arm should rotate with no sign of "wobbling" If the steering tends to "stay where it's left" while driving rather than returning to center, the seller has probably cranked up the center arm to try to hide slop.
Check the ball joints with a pair of water pump pliers. Squeeze the ball joint from the top and bottom (taking care not to put pressure on grease nipples, if present) if it "compresses," it is worn out. Replacing worn tie rod ends is relatively easy, but ensure that there's only play in the ball joint and not in the threads between the rod and the end. This will require replacing the rods themselves.
Brakes
To check the brakes, push the pedal down and hold it. If the pedal travels slowly to the floor, there is a leak in the system. If it is apparent the system is leaking, start off by checking at each wheel. Remove each wheel in turn and check for leaks. Look for leaks from the calipers on disc brake equipped vehicles, and wheel cylinders on drum brake equipped vehicles. On drum brake vehicles, put each drum back on and feel how easily it pulls off. It is usually very difficult to coerce a drum to come off, but once you've broken the "seal of rust," they should only be slightly snug, if they come off too easily the wheel cylinders need adjustment. Out of adjustment wheel cylinders will also show up when you depress the brake pedal in the form of excessive pedal travel. Check the shoes for reasonably even wear and thickness and look for any signs of scoring in the drums. Try to turn the adjusters on the wheel cylinders. If they're seized, they will need replacement. You can get a rough idea if the drums are warped or not by putting them back on the truck and spinning them. There should be even resistance thought a complete rotation.
Check all the steel lines for excessive corrosion or kinks. Flexible lines can be checked by "kinking" them back on themselves. If the edge that is in tension shows signs of cracks, it needs replacement.
Suspension
Many people will replace the factory suspension anyway, so for them damage here is of little concern. If the stock suspension is to be retained, there are a number of items that should be checked. Check the spring packs for broken or bent leaves. If there are no shoulders on the bushings or the shackle pin doesn't appear to pass through the center of the spring eye/spring hanger the bushings will need to be replaced. Check at there is no movement of the shackle pin relative to the shackle plate. Pre-81 stock shackles are prone to the pins working loose.
Looking at the condition of the U-bolt ends below the spring plate will give clues to the use of the vehicle. If the U-bolt ends are bent/scraped, the truck has seen some off road beating. While looking under the U-bolt plate, ensure that you can see the nut and spring pin. The pin will sometimes break in the middle of the spring pack causing the bottom chunk to fall out. Replacing the pin requires removing/replacing the U-bolts as well.
Check that the shock mounts on the rear cross members and u-bolt plates aren't broken. Frame/axle mounted broken pins must be cut out and new ones welded in. On 40 series, the top front shackle mount pin will sometimes develop play relative to the shock mount tower. If that is the case, it can temporarily be fixed by adding another washer to the large nut end of the pin, but will eventually require proper replacement which involves welding/boring out the tower.
Body
This is probably where you'll find the greatest variance in Land Cruisers. Some trucks are pristine and have been hermetically sealed in their garages all winter, whereas some have been used to launch boats in the ocean. The former will have a body. The latter won't. It's rare that you will find a Land Cruiser with a rust free body in the Eastern or Midwestern USA unless it's been brought in from out west. Most of the well preserved trucks spend most of their lives in the Southwest or Western states.
The problem areas primarily for 40 series but also 55 series are: (probable order of occurrence)
-along the seam between the sides of the body and the tops of the fenders in
the rear
-under the back doors LIKE THIS
-behind rear taillights where mud can get trapped LIKE THIS
-the "box section" that runs under the door sills
-the lower edges of all doors LIKE THIS
-on the fenders around the turn signals
-on the fenders where the support brackets from the frame attach
-along the sill that runs down in front of the doors
-the windshield frame under the rubber gasket
-the lower edge of the hard top and the steel drain sill under the fiberglass
-don't forget to pull back all the floor coverings and look for holes in the front floor boards and rear bed
-along the seam on the front of the hood. The above is for an FJ40/ FJ55.
The problem areas for the 60's and 70's are
-the lip around the fender wells
-the lower edges of all the doors
-the rear quarter panels
-under the rubber gasket around the windshield
-under the mud flaps
-basically any seam around the rear wheel wells.
-the seams in the front foot wells
Finding a 60 that has the dealer installed aluminum running boards is a good sign. Intact running boards indicates that the vehicle had never really been used offroad and they also prevent the rocker panels/lower door edges from being hit by spray from the tires, decreasing the likelihood of rust.
Frame
The most common areas for frame rust on a 40 series are the gusset plates above the rear-most spring hangers, the rear crossmember, and the diagonals that run from the frame rails to the crossmember. As long as the frame rails themselves are okay, most of the gussets/brackets can be replaced. If the steel looks like its "delaminating," it is shot.
On pre 1981 trucks, the frames also tend to crack where the boxing ends above the front most rear spring perches. The crack tends to run longitudinally from the rear-most rivet on the perch towards the back of the truck. The spring perches can also be tweaked, especially if the truck has been running extended shackles. As you sight along the frame rails the shackles should be perpendicular to the bottom flange. Tweaked fixed pin spring perches are rarer, but if a rear one is out of alignment, chances are the frame has cracked. Because of the stronger design, perch/hanger problems aren't as common on post- '81 40s and 42s. Feel through the holes on the inboard sides of the frame rails. Large flakes of rust are a sign of problems to come.
60s and 70s only real problems stem from rust. Their frame designs don't have the same large holes as on 40s so they're harder to clean and more prone to trapping crud and rusting. Feel through the small access holes for signs of rust flakes. The worst spots for frame rust on 60s and 70s are where the muffler is next to the frame. It is possible for the steel to be weakened to the point that a screwdriver can easily be poked through it with no outwardly visible warning signs. The other big problem area is the rearmost section of the frame where it is just a channel (as opposed to fully boxed)
Edited by Rob Mullen - ramullen@home.com
Information shamelessly pilfered from:
Against All Odds: The Story of the Toyota Motor Corporation and the Family that created it
by Yukiyasu Togo & William Wartman; New York, USA : St. Martin's Press,
1999 ISBN 0-312-09733-6
Das Grosse Toyota Land Cruiser Buch
by Martin Braun, Thomas Ronnberg; Munich, Germany : AC Verlag, 1993.
ISBN 3-86087-140-4
Downey Off Road Manufacturing Catalog
Specter Off Road Catalog
TLC Engine Conversion Kit Instruction Manual (Advance Adapters)
Toyota Land Cruiser: 1956-1984
Compiled by R.M. Clark; Surrey, England : Brooklands Books Distribution Ltd.
ISBN 1-85520-0473
Toyota Parts Microfiche
Toyota Trails (TLCA Newsletter)
Toyota Truck & LC Owner's Bible
by Moses Ludel; Cambridge : Robert Bently, Inc., 1995
ISBN 0-8376-0159-2
Toyota USA and Japan Service Bulletins
Toyota: A History of the First 50 Years
by Toyota Jid&oring, sha Kabushiki Kaisha; Toyota City, Japan : Toyota
Motor Corporation, 1988.
Toyota, Fifty Years in Motion: An Autobiography
by Eiji Toyoda, Tokyo; New York : Kodansha International, 1987.
Toyota Repair manuals
Various 4x4 Magazines
Contributors (Although they may not have realized at the time
Rory Arms, Paul Bech, Gary Bjork, Drew Eckhardt, Lars Gottberg, Neil Kapperman, Steve Kopito,
Kerry Manning, Willem-Jan Markerink, Andrew Murphy, Greg Overton, Park Owens, Marv Spector, Ian Staines, Roy Stockman, Jeff Zepp, Toyota Canada Inc.
Happy cruisin'!
Marshall
Upstate Cruisers
TLCA
RIP Andrew Farmer
Old 01-22-07, 07:16 AM   #3 (permalink)
THC
Trollhole's Avatar
Garage
Land Cruiser Questions
by Greg Overton
Name:
Phone:
Price:
What year is the Land Cruiser?
What color is it?
What Is the actual milage if known?
Does the vehicle have a clear title?
Has the vehicle been garaged? Body/Frame
Rate the body on a scale of 1-10 with a 10 being perfect
Is there rust? if yes please describe -
Describe any body/frame damage?
Condition of windows?
Rear wheel wells cut for flares?
All body logos present?
Has vehicle been repainted? if yes, original color?
Has the top been removed?
Is there rust in the floor?
Please rate the tires - Excellent, Good, Fair, Need's replacing
Original Wheels and Hubcaps? If no, please describe. Engine and Mechanical
Rate the engine on a scale of 1-10 with a 10 being excellent
Is this the original engine/transmission?
Has either engine/transmission been rebuilt?
Original carburator or after market?
What repairs does the engine/transmission need?
Does it leak fluids?
Does it burn oil?
Is the clutch in good shape?
Have brakes been serviced? When?
Transmission - in good working order - both high and low range?
Does it shift smoothly?
Power steering?
How many inches of play in the steering?
Air Conditioning?
Winch?
Aux Fuel Tank? Interior
Rate the interior on a scale of 1-10 with a 10 being perfect
What is broken or missing on the interior?
Seats Ripped?
Headliner sagging or gone?
Original rubber mats?
Rear Jump Seats present?
Dash Pads Ripped or cracked?
Dash board cut out for add-on switches or stereo?
Original Radio?
Gauges working?
All signals working?
Brake lights?
Head lights?
Turn Signals?
Licence Plate lights?
Hazards?
Wipers?
Washers?
Instument lighting?
Interior Light?
Original Owners manual present?
Inspection light present?
Jack present?
Toolbag Present?
Rear Heater?
Any additional add-ons, options, information
Questions about the Questions?
Contact Greg Overton - gregoverton@mchsi.com
Marshall
Upstate Cruisers
TLCA
RIP Andrew Farmer
Old 01-22-07, 08:05 AM   #4 (permalink)
1phrogguy's Avatar
Outstanding write up, I wish I had this info before purchasing. Needs to be in FAQ's. Or even a sticky.
1phrogguy is offline   Reply With Quote
Old 01-22-07, 09:05 AM   #5 (permalink)
No brag..just fact
Well done!
3DAMAN! is offline   Reply With Quote
Old 01-22-07, 09:20 AM   #6 (permalink)
jfz80's Avatar
Garage
Good going Mashall!!! where was it when i needed it last week though (see UC hoarders post)
Definately FAQworthy material.
Jason
__________________________________________________ __________
95 FZJ80 -- Expo Rig
72/4/6/7/8/9 FJ 55 -- Trail Rig
77 FJ-45 -- DD
.................................................. ................officially toyota poor
jfz80 is offline   Reply With Quote
Old 01-22-07, 11:42 AM   #7 (permalink)
Yea, should be in the FAQ.
Here is the link if need to bookmark it.
D.F.Morse
1994 FZJ80 Kazumatized 74000 mi
1979 FJ-40 74000 mi
Here endith the lesson
dfmorse is offline   Reply With Quote
Old 01-22-07, 03:43 PM   #8 (permalink)
TRESSEH's Avatar
Well Ummmmmmmmm Wow. If I Read This Before I Bought Mine, I Would Have Been Tormented, But Would Still Have Bought It. But A Great Must Read For A Future Buyer. A Must For F&q
TRESSEH is offline   Reply With Quote
Old 01-30-07, 11:27 AM   #9 (permalink)
overton's Avatar
Funny thing
I sold a Cruiser a to a nice guy in WA. He sent me my own list of questions that I developed to answer. I thought that was cool.
Greg
Visit www.lcnation.com
overton is offline   Reply With Quote
Old 09-24-07, 10:28 AM   #10 (permalink)
WOW!!! Show me the 40 that passes that inspection.! I bought mine based on 5 pics and a 10 minute conversation, 2000 miles away. Last week! Should I even go through the checklist now? Why torture myself. GREAT THREAD!!!!
82' FJ40 02'Vrod 02'Disco SE7
JR FJ40 is offline   Reply With Quote
Old 09-24-07, 11:06 AM   #11 (permalink)
450,000+ mile club
JohnnyC's Avatar
good write-up...you should do a list ... poor / fair / good / very good / excellent..and what to expect from each...and some pics of each catagory...also aproxamate price range....like a kelly blue book...looks like you are a really good writter and organizer
like this...but there prices are not what the TLC community are paying and expect to pay:
http://www.kbb.com/KBB/UsedCars/Pric...uizConditions=
kbb doesnt go back far enough
JohnnyC is offline   Reply With Quote
Old 09-24-07, 02:24 PM   #12 (permalink)
THC
Trollhole's Avatar
Garage
LOL. Boy do you have that one wrong.
I didn't write the article. I copied it from a search I did on buying a Land Cruiser. Figured it would help some people out. Would have been nice to know when I bought my first one.
Marshall
Upstate Cruisers
TLCA
RIP Andrew Farmer
Old 09-24-07, 05:04 PM   #13 (permalink)
Weedhopper's Avatar
Did the same thing. Bought our vets wifes cruiser, never drove it, took her word for it, knew who serviced it and bought it over the phone. Actually it was kinda cool. Most of the surprises were inexpensive ones. Kinda like Christmas morning!
78 FJ 40 Russstard..and a sistership for parts
7.5 Fishmerwester plow
Weedhopper is offline   Reply With Quote
Old 09-24-07, 05:39 PM   #14 (permalink)
F-junker's Avatar
I was looking up a bike value on kelly' (sorry it was NADA NOT Kelly) site and for fun looked under land cruiser. I don't remember if I got back to 78' or if I used maybe 81-84 but I came up with a "retail value" from 2000 up to 11 or 12,000. I was shocked.
Not to mentioned I was shocked to find my 1st generation 87 4runner was worth quite a bit more than my 1990's Ford Probe!
I know these values are a guidelines really but I was suprised there was even a value listed for the Fj-40. I can't remember if I looked that up under a classic car profile or not. Check it out.
1978 (mostly) FJ-40, lift, 2F, bigger tires and custom swiss cheese body panels to reduce weight!
Various other toys 87 4runner, Motorcycles Ducati and Triumphs with an old Mach III in the mix.
F-junker is offline   Reply With Quote
Old 09-24-07, 05:43 PM   #15 (permalink)
Color Please
What color ist this mustard-yellow on the first photo? the GOOD CRUISER?? i want to paint mi fj with this color. thanks ...
Emmanuel N Serna MD
dr.serna is offline   Reply With Quote
Old 09-24-07, 10:06 PM   #16 (permalink)
450,000+ mile club
JohnnyC's Avatar
Ahhhh a copy cat
i retract my coment that you are a good writer LOL
Old 09-25-07, 12:58 AM   #17 (permalink)
crushr's Avatar
The author Greg Overton is a mud member and supporter. That is a cut and paste from his website. By any chance did you ask him whether he wanted it posted here?
I do more before 6 p.m. than most people do all morning.
crushr is online now   Reply With Quote
Old 09-25-07, 06:50 AM   #18 (permalink)
THC
Trollhole's Avatar
Garage
No I didn't because it was linking all over the internet in all kinds of places on every single other Land Cruiser website. I really didn't think he would mind sharing his words of wisdom. Probably the single best article I have ever read about 40's and what you should know. I gave credit where credit is due.
Don't turn this thread into a pissing match. PM me if you have a problem.
Marshall
Upstate Cruisers
TLCA
RIP Andrew Farmer
Old 09-25-07, 07:55 AM   #19 (permalink)
Location: Australia down in that lil dot at the bottom of the map
hahahahaha at least the bezel is the right way up
oh yeah on the cut and paste saves me searching
wish i had this write up to help me out when buying mine by the time i got 10 metres up the street i was in love and didnt
give a **** about the problems to fix
83 BJ42 LX
smack is offline   Reply With Quote
Old 09-25-07, 08:11 AM   #20 (permalink)
450,000+ mile club
JohnnyC's Avatar
the reason why we have message boards like this is for the shairing of information...which would benefit the TLC community.
still...thanks for posting this up...it keeps a discussion ongoing of what to look for in a TLC.
File sharing + IH8MUD = Good Cruiser
LinkBack to this Thread: http://forum.ih8mud.com/40-55-series-tech/132481-buying-land-cruiser.html
Posted By For Type Date
Is this a good buy?? FJ 40! I need Help! - Toyota FJ Cruiser Forum This thread Pingback 08-21-09 08:46 AM
Should I buy my co-workers FJ40? - Toyota FJ Cruiser Forum This thread Refback 08-19-09 05:25 PM
F2 Toyota strait six motor. - Toyota FJ Cruiser Forum This thread Pingback 07-11-09 02:57 PM
Vintage FJs? - Toyota FJ Cruiser Forum This thread Refback 05-10-09 09:02 AM
1970 Fj40 - Toyota FJ Cruiser Forum This thread Pingback 03-14-09 02:35 PM
Ford F 250 Hubcaps, Ford Explorers Accessories, Ford F 350 Running Boards - Brighterheadlights This thread Refback 03-08-09 05:36 PM
Bumper Repair In Jacksonville, Bumper Repair 2000 Hyundai Sonata 4 Dr Gls, Bumper Sticker Motorcycle Safety - Dieselmotorcycle This thread Refback 03-08-09 09:22 AM
Lone Star Dodge Chrysler Jeep, London Ontario Vibe Pontiac For Sale, Long Beach Bmw - Gasfires This thread Refback 03-08-09 06:02 AM
Wiring Turn Signals In Classic Cars, Wiring Sirius Stratus Radio Into Mini Cooper, Wisconsin Full Service Car Wash - Classictelevision This thread Refback 03-07-09 02:50 AM
Trailblazer Ball Joint Replacement, Traditional Vs Suzuki, Trailblazer Replacement Parts For The Interior - Ethosgas This thread Refback 03-07-09 02:39 AM
Might be picking up an run down FJ40 - Toyota FJ Cruiser Forum This thread Pingback 02-19-09 06:54 AM
What do you think this is really worth? - Toyota FJ Cruiser Forum This thread Pingback 02-05-09 04:39 PM
Need help buying a FJ40 now!!!! - Toyota FJ Cruiser Forum This thread Pingback 12-12-08 08:50 PM
4runner owner lookin at an FJ - YotaTech Forums This thread Refback 11-15-08 11:06 AM
Thinking about buying an FJ 40! Need help deciding! - YotaTech Forums This thread Refback 11-14-08 09:26 PM
Toyota FJ Cruiser Forum - View Single Post - Buying a FJ40 This thread Refback 11-11-08 11:08 PM
'78 FJ40...should I buy??? - Toyota FJ Cruiser Forum This thread Pingback 10-04-08 07:26 PM
Buying a FJ40 - Toyota FJ Cruiser Forum This thread Refback 06-03-08 06:34 PM
FJ40...Should I? - Toyota FJ Cruiser Forum This thread Refback 05-18-08 08:08 AM
FJ40...Should I? - Toyota FJ Cruiser Forum This thread Pingback 05-17-08 07:03 PM
What to look for when playing w/ the idea of buying an fj40 - Toyota FJ Cruiser Forum This thread Refback 05-13-08 08:33 PM
What to look for when playing w/ the idea of buying an fj40 - Toyota FJ Cruiser Forum This thread Pingback 05-13-08 09:15 AM
Old FJ-40 - Page 2 - Toyota FJ Cruiser Forum This thread Refback 04-15-08 02:52 PM
Old FJ-40 - Page 2 - Toyota FJ Cruiser Forum This thread Refback 04-15-08 12:06 PM
1971 Fj40 - Toyota FJ Cruiser Forum This thread Refback 03-19-08 04:14 PM
Your thoughts on Pigs (FJ55s) This thread Refback 01-31-08 11:24 PM
Your thoughts on Pigs (FJ55s) This thread Refback 01-31-08 03:21 PM
I found this FJ40 for sale - Toyota FJ Cruiser Forum This thread Refback 01-13-08 10:57 AM
