Identify this Clutch Master Cylinder - Please
I need to replace the Clutch Master on my 1962 FJ40.
It looks like the model that I would order for this year is no longer available from SOR or Cool Cruisers and I'm not even sure this is the original. Can anyone help me:
1. Identify the one that it is and
2. Let me know where to get a replacement.
The body has "58" stamped on it. The plastic bottle has "47221-12010" on it and the inside of the cap says "AISIN".
Could this be it? http://us.st11.yimg.com/us.st.yimg.com/I/coolfj40_1908_5669021
Thanks,
That's the 7/70 - 1/75 version, I believe (SOR 018-01C-OEM). What I have on my 9/70.
If you get the earlier version, you'll find the fittings are different, and you'll have to replace everything (master, solid tube, hose, slave). So, maybe you want to stick with the version you have.
It looks to me like someone has already installed the "update" master and line for this set up....the original hard line was larger and the fitting on the master was different.
:beer:
Yup, as IDave said, that's the 71-75 model. Earlier used the bigger banjo bolt; newer had the hard line screw directly into the cylinder.
I still stock the 71-75 cylinders. You can call the shop to follow up.:)
Best
Mark A.
Confirmation
So somewhere a previous owner upgraded this clutch to the 70-75 year. The part picture I was posting came from CoolCruisers website but they don't have a 70-75 clutch listing. They have a 9/65-6/70 and a 7/70-7/80 http://coolfj40.stores.yahoo.net/clutmascylfj.html.
I guess you are telling me that I have the 7/70-7/80 already installed? Looks like I better call Mark for more confirmation.
the oringal 64 would have looked like this(brand new OEM)
Like folks have said, it's an early 70's cylinder. I recently bought one from CruiserDan, so the it's still available from the dealer.
