Trade Your fj40 for my fj60
Charleston SC
August 1984 FJ60 in medium blue - Mileage: 185,xxx
This 60 was bought from a broker who had sourced this cruiser from the original owner. I am the 2nd owner to have ever registered this cruiser. This cruiser spent 99% of it's life in Washington state, With it having zero rust! Now it's home is Charleston SC. The original owner as well as myself kept it garaged, and didn't smoke or allow pets. The paint is original and for it's age is amazing! clear coat is flaking on two doors that's it. I bought this 60 last summer, and I have spent a lot of time and resources getting it to where it is now. I have receipts for most of the work due to me not being very mechanical. I have since hooked up with a landcruiser club and have learned a lot. I will list what I have done, and if it was a mechanic or if it was me and my fellow cruiser heads. mechanically this thing runs like a top, very smooth idle 650rpm/ac idle 900. when cold 4 or 5 pumps on the gas pedal and it cranks right up. When hot it just turns right over. This 60 is desmogged as well. I have kept most parts I have taken off this 60 and it will come with it, plus I have bought lots of other things for it in case things were to break (i'm a worry wort!) Comes with factory skid plate, was taken off for pics.
All this was done in the past 11 months!
- Fountain of youth full tune up kit from cool cruisers (mechanic)
- Toyota Land Cruiser FJ60 Champion 3 Row Aluminum Radiator - comes with old one and it didn't leak (me)
- All 3 belts replaced with new belts (mechanic)
- Troll hole Carb - comes with original carb it worked but wanted the THC for better performance (mechanic)
- New Alternator - comes with old one but it needs work (mechanic)
- New hood bump stops and new hood stand retainer clip (me)
- All new vacuum lines (me)
- Fixed the rear window washer hose issue (me)
- 3 all new window wiper blades along with all new wiper blade Toyota oem arm covers (me)
- New radio antenna (me)
- New License plate lamp kit - comes with old one (me)
- All rear tail light bulbs replaced (me)
- Bumpers were taken off and back of bumpers were undercoated to prevent rust (me)
- Old Man Emu/ Man-A-Fre FJ60 4-inch Suspension w/ Shackle Reversal Kit (mechanic)
- Wrangler dura-trac 33 inch tires (tire shop)
- All new exhaust- pipe and muffler (mechanic)
- Front brakes- new rotors and pads (mechanic)
- Rear brakes- brake cylinder replaced and drums re surfaced. (mechanic)
- front drive shaft lengthened- as well as front and back drive shaft balanced (mechanic)
- New charcoal canister - comes with old one (me)
- New fuel oem gas cap - comes with old one (me)
- New oem front wheel well rubber skirt kits (me)
- New fj62 mirrors - comes with original fj60 mirrors as well (me)
- New oem check valves for front head light washers - so they actually work! comes with old ones (me)
- New front grill, OEM Toyota emblem, and headlight grills - comes with originals (me)
- New OEM side markers
- Had diffs fluid changed, Transfer case and transmission flushed and serviced (mechanic)
- New OEM fuel pump
- New JT Outfitters Hydraulic Clutch Conversion. That's the master, the slave, and stainless steal hose makes the clutch very crisp! great upgrade (mechanic)
- New Autocraft Gold Battery
- I just sourced a un damaged air cleaner hose, will be swapping that out soon as it arrives. (me)
- Has the original jack and jack kit
- Sor High density seat foam and new upholstery - seat frames were treated and painted - comes with original upholstery and foam(only driver seat side is ripped). (me)
- Hexagon floor mats and some custom window sun-visor
- All interior bulbs have been replaced with LEDS - instrument cluster- hvac- dome lights (me)
- New pioneer head unit and Polk Audio speakers - Wasn't oem tape deck in it so that's why I replaced it (stereo shop)
- New OEM gas, brake, and clutch pedals
- AC was serviced and Charged the 1st month I got it - still blows ice cold! (mechanic)
The Good
Everything works on this 60 as it should. I have spent much time making sure of this, there is no issues! The head light washer squirts, the carb fan cuts on for 15 mins after vehicle is shut off, 4wd works perfectly, the locking hubs turn smooth as butter. interior is perfect except for carpet has some traffic wear but nothing terrible. Headliner is perfect with no tears or droop. The clutch is crisp and shifts with ease! The 2F is very peppy for a 2F. I have driven a 40 with a 2f and it felt very sluggish in comparison.
The Bad
Very slight front timing cover leak - add half a quart maybe every 1500-2000 miles.
two passenger doors have clear coat flaked off - These pictures were with no spray on detailer or wax, I've been slowly working the flaking down the doors with pressure washer. When waxed you can't even tell the clear coat it gone. Driver side sun visor likes to flop in your face sometimes.
The Other
When I said im a worry wort and buy extra stuff I meant it! I have a whole other set of ac vents two of which are close-able. I was going to eventually change the two middles with the close-able ones, so all vents could be shut off. I have a whole extra set of seat belts. I have a few windows cranks, headrest post, clips for the grills, extra driver side seat track, extra led bulbs plus original bulbs, and even a full knuckle rebuild kit ( doesn't need it, but one of the most common issues with these so I went ahead and bought it). Also comes with a ton of old school manuals, original window sticker, and some interior sticker decals (in case the ones on the glove box ever began to flake) There is also other things im forgetting for sure that will be included.
PICS: LINK BELOW
FJ60
I'm not wanting to sell this as much as trade it. I don't need to sell it or trade it for that matter. Cash price would be around 23k.
Side note, I kept everything I have replaced and will come with this cruiser. I also have parts and stuff that havent been used. Even a knuckle rebuild kit. 60 knuckles are fine but I went ahead and bought the kit to have it.
That looks great-don't let it get away!
No matter how nice a 40 is, it is not as good as a 60. Keep this great specimen or you will have regrets forever.
I get it that 40s are cool and all, but they are not close to as useful as a good 60. And I'm saying that from the perspective of someone who has owned both for 15 years.
You forgot to mention you put on FJ62 manual mirrors which is another great upgrade.
Your correct I did, also reason why this cruiser is in such great shape is cause last year I became the 2nd owner. It was garage kept one owner since 1984. I come from a Jeep background 14 years until last summer. Not being able to take the top and doors off bums me out. This is a weekend vehicle and my wife's not going to let have two haha. So I figure 40 is best of both.
You should talk to the wife.
:cheers:
Clutch was replaced 4 years ago. Clutch is very tight and smooth. The knuckles were rebuilt in 2002. This comes with a knuckle rebuild kit as well. Not that it needs it but I have a bad habit of stocking parts. Transfer case has not been rebuilt but has been serviced. I recently had it serviced two months ago. The clutch and the knuckles is from the original one owner as told to me. The old owner also said it had a factory recall on the gas tank and it was replaced as well. The previous owner took really good care of this vehicle but it was a 3rd party who sold it to me and had to relay info to me. He did not have hard copies so I'm going off his word.
Also I bought all these manuals and it has to original window sticker too boot. I also have spare window cranks and interior door handles. As well as a whole other set of ac vents. Like I said I'm paranoid about stuff breaking and not being able to get the part.
depends on what someone would be willing to pay. Since i don't need to sell it I would deff hold out for top dollar 20k-22k range. if i was wanting it gone i would do lower.
