Anyone install a yellow box and have a similar problem?
I installed the Yellow box per the instructions using the instructions and woody's write-up and knowing the wires are backwards in the photos. The instructions can also be found at http://www.blackrobotics.com
I measured 12.46 volts between power and ground at the connector
White to input
Grey to output.
Yellow Box powers up and goes through self test.
I tried swapping the in and out wires and the yellow box blinks the switch settings all the time even when I am moving. The speedo does not work.
I install jumper connector at end of harness (remove yellow box) and speedo works.
I remove the harness and splice original wires back together and the speedo again works.
I did originally wire the power at the cig lighter, according to the wiring diagram, they are both off of acc power.
I then moved the power wire to the yellow pin 6 wire in the same harness as the speed sensor with no effect.
I was assured I was provided the 2 wire set-up.
Based on my troubleshooting, I think I have a bad unit. I compared these instructions to the True Speed write-up on Christo's site and I am using the same wires as shown there and in woody's write-up as confirmation.
I have contacted the manufacturer and the folks I bought it from
Thanks for any pointers and Merry Xmas.
White to input
Grey to output.
This tells me I have proper power and ground.
Yellow box blinks to indicate switch settings. Blinking on switch settings continues until start driving. While moving, blinking stops. When I stop at a Stop sign, blinking resumes to show switch settings. Speedo does not work.
This tells me the yellow box senses the vehicle in movement and stops blinking per instructions. (When white is on input) and when I swap the wires the lights blink all the time.
