I wanted to address the heat issue under the hood. The turbo system moved the heat up higher, right under the hood. This is causing some plastic things to deform so this issue need to be addressed ASAP in my case. Until I find someone who can create louvers on my hood, I'm going to space up the rear of the hood by adding maybe, 1/4" alum spacers between the hood and the brackets/hinges Someone in Denver has this hood stamping machine for making louvers, according to
@treerootCO. His 80 has a pair of these louvers and they look totally sexy. It might be worth a road trip for me to have this done in DEN vs cutting rect holes then install louvers. I think two holes are needed on both sides of the hood, between the hood braces to let the trapped heat escape.
After a run, I am unable to touch either fender edges next to the hood edges. I should also think about wrapping the J pipes and regretting not doing this in advance of the turbo install.
