Wiring guidance
Sutter Creek
I had @Coolerman refurb my wiring harness and add a fusible link. The white/ blue wire is connected to my alternator and the solid white wire is the fusible link connected to the + battery. Where do these get connected to? Fuse block? If so where? Thanks in advance
Saw your year in your signature....this link has one for a 71
I didn't look at the diagram so I could be way off, but those look kind of like the wires that plug into the Ammeter on the back of the instrument cluster.
Edit: Changed the word Voltmeter to Ammeter. Thanks @73FJ40 .
I didn't look at the diagram so I could be way off, but those look kind of like the wires that plug into the Voltmeter on the back of the instrument cluster.
Ammeter. The stock gauge measures amps.
They must be connected a certain way, check the wiring diagram for guidance.
What wire gauge specification is the stock Ammeter wiring? Can't use stock ammeter with upgraded alt, so if using a new ammeter, the wiring becomes the constraint.
So about 30 amps max on that circuit. Wouldn't work for an upgraded alt and ammeter. Would need to use a seperate ammeter and use stock wires for signal to display.
