Winterizing the 80
Baton Rouge
I am preparing to make a solo 3000 mile road trip to Colorado just after Christmas. I am concerned about the cold because we just don't get it down here and not sure how my rig will react.
I do not plan on going offroad on this one. Do I need to do any special maintenance before I hit the cold temps? Any other suggestions for what to pack regarding winter driving?
I would say get everything greased up. Fresh oil change and check all other fluids. Check the brakes, all the normal items.
I did a 3300 mile road trip at the end of October and had no issues. I just did an oil change and made sure everything checked out.
And some de-icer windshield washer fluid.
And pack a light foot on the gas pedal as well. From what I could read on this board, there's a good number of 80s out there that have been totaled during wintry conditions on snow or ice covered highways. Enjoy and take pics!
X2 on the windshield washer fluid. Since you prolly don't run the anti-freeze type, before you leave, dump out your windshield washer reservoir completely. Buy some with antifreeze, good for 0 F or -25 F should work. Fill it up with the new stuff and squirt some through both the front and back to purge the old washer fluid out. This will prevent it from freezing and blocking your lines while your parked over night. I run it year around, so I don't forget and get caught. Also make sure your wiper blades are in good shape (don't streak). If you're driving in the snow or cold weather, I've found it helpful to keep your windows from fogging up by running the fan at the next higher speed than you'd usually set and have the air coming out both the defrost and the heat vents (position between defrost and heat). The more people in the car, the more the windows will fog up. Also, keep the air on the fresh source, NOT recirculate - this helps cut down the moisture from our breath. One thing about the 80, it has a damn good heater in it, at least mine does! That get's the most compliments from the :princess: of any vehicle we've owned. And like grolar said, light foot on the skinny pedal. Good luck and have a safe and enjoyable trip!
Oh, and buy an extra gallon of the ww antifreeze to keep in your rig for the trip. I've found that in bad weather you really go through the stuff.
X2....and add to that some new wiper blades. (80t0ylc beat me to it...)
When you check your coolant get a simple antifreeze tester and make sure you have adequate protection.
I lied. This is Louisiana today:
Crazy.
So did you get it winterized in time for a freak southern snow storm?
No, I was waiting to make sure my trip is on. I did, however, discover that my rear defrost does not work. I will try to clean the contacts this afternoon, but is there a way to test it if the window is not fogged up?
You should be able to pull the plug and use a voltage tester to see if you get the thing to light up, or a ohm meter would work as well.
Make sure you coolant is up to the task. If you haven't had a coolant flush in a couple years, now's the time.
Other than that, our rigs are pretty much 'cold ready'. Unless you're going to Alaska or somethin'.
I don't know if you can buy one there, but get yourself an ice scraper and snow brush. There is nothing worse than trying to scrape ice/frost with a credit card followed by driving while looking through the windshield through a little peephole as if driving a tank.
Thanks guys. Flushed a couple of months ago, but I still plan to test the coolant as part of my pre-trip maintenance.
I'm not sure where in CO you are headed but if you take I-70 thru western kansas and eastern colorado it can get very dangerous out there if a blizzard kicks up. Make sure you have plenty of gas, blankets, coats, gloves, food, drinks, flashlight, candle in the rig.....just some basic survival stuff in case you get stranded. If it gets bad out there they close the road and you don't want to get caught in that!! Good luck and have a safe trip. BTW nice pics in LA, so much for Global Warming........:rolleyes:
Never hurts to be over prepared.... The one time you don't think you will need it is when God will throw you a challenge. That route through CO can leave even the most prepared wishing they had planned for worse. Matches!! Don't forget em.
BTW.... Global Warming isn't just what it sounds like. Global climate change is part of the same slogan. Thus the freak snow storms in the south!
oh....that's right.....its called Global Climate Change now. I guess since its not warming anymore.........because of global warming it snowed in LA? When was the last time it snowed in LA? I also heard it snowed in HOUSTON! I'm confused :bang:
sorry didn't mean to hi jack.............ditto on the matches;)
Dunno how cold it will be in CO or where you'll park your rig but you might need a block heater. When it gets below -30C here in Winterpeg, especially overnight, we plug our block heaters to keep the engine oil from freezing.
Safe driving.
We had a similar storm in Baton Rouge in 1988. Twenty years ago I'd never heard of global warming, er climate change, er PC bull****. No worries on the hi jack. I'm with you badger.
serious though, check the weather forcast before heading into western kansas, I almost got caught in eastern CO in a blizzard on my way to Moab (Jeep Easter Safari) 40mph wind and 10 inches of snow makes for no fun! Luckily we made it into Denver with no trouble. I was so stoked to be headed to Moab that I forgot to check the forcast and was totally caught off guard when the blizzard hit!! Check all the mechanical stuff and you should be fine.
Maybe charge or check (or replace) your battery, and make sure the posts are clean; the cold sucks the life out of them. Synthetic oil?
