Winterizing the 80
1 -I would put a couple applications of rain-x on the windows if you can in a garage or when it warms up over 55 degrees. When you really want the rain-x during a snow storm, you will not be able to effectively apply the stuff. Rain-x also makes anti-fog stuff you can put on the inside of the windows -- probably worth a try.
2 - Plenty of warm clothes, emergency blankets and water.
3 - I don't have any experience with my 80 in a real winter, but a couple big bags of sand or kitty litter were a requirement in the winter when I had my j**p in Idaho. They give you added weight/traction in the back. They can also help you drive out of a ditch. (the diff lockers should help with that too though) . . .
I am making a 3K+ mile trip from next fri to Jan 3rd. I will be taking I-80 to UT then I-15 to Spokane, then I-90 back.
One thing I like to bring with me is a battery jumper pack.
I will have my GPS in case I have to make any detours due to road closures. Hopefully inclement weather won't block the signal.
Also make sure your spare tire is pumped up.
A small collapsible shovel would be nice to have as well.
I plan on being light on the skinny pedal as well. I have seen a lot scary threads involving 80's and ice.
Best of luck on your trip!:popcorn::cheers:
What no one has mentioned for those in salt prone areas is under-protection.
Before the winter I used to drive the 80 ontop of a large tarp and go under there with some cheap SAE 30 oil from Wally World and a rag and do an undercoat of the entire truck. A nice layer of oil does wonders against salt infestation. Let the truck drip over night and you are ready to go again in the AM.
I did this about 3-4 times during the long OH winters....
Just make sure that your anti-freeze is at normal specs. and that you have a decent battery. You should be fine. I grew up in Colorado, and live in Wisconsin. I don't do anything different up here even though it gets down to -10 or colder. My truck normally lives outside, and starts right up.
Anybody else besides aey_bee_see come from a really cold place. Once my rigs suspension gets built in Washington It will be living in Bismarck ND. Its in a warm garage right now but next winter it might have to live on the street if I cant find a place with a tall enough garage. The temps there can get to 30below without wind chill. What kind of failures can I expect? I know with some military trucks we remove the steering stablizers because they freeze. Any good block heater ideas? I plan on getting a remote starter that starts it every couple of hours for those cold nights.
Thanks
Thanks
I bought a block heater from a fellow Mud member that lives in N.D. I wouldn't worry about a remote starter that starts every couple of hours unless you won't have access to a power outlet. If you can discretely run an extension cord out to the street, a block heater, oil pan heater, and a battery heater would definitely guarantee your engine will start in any weather N.D. could throw at you, although all of that might be a little overboard.
The block heater can be purchased through various sources in Canada. Here are some of the links describing the part numbers, installation etc.
https://forum.ih8mud.com/80-series-tech/111624-block-heater-installation-estimate.html
https://forum.ih8mud.com/80-series-tech/107778-winter-coming-block-heater-installation.html
Make sure you get one that has the exact numbers cast into it since other members have had problems getting the wrong size. Installation sounds pretty straight forwards. I plan on installing it on the drivers side front freezer plug hole.
HTH
Thanks for the info nicholas. Anybody have a good idea on what to to with the cord. I dont like the way they usually just hang out the grill. I was thinking of having some kind of plug flush mounted to the front bumper. Kind of like an outdoor electrical outlet.
I call it global weirding. haha
Colorado mountain driving can take a real toll on a weak coolant system. The very long hills on I-70 will beat up a weak coolant system. So if you feel that there are hoses that you have not replaced that "should" be replaced, do it up before you drive into the high country.
I'm sure this is redundant, but...most accidents in cold, icy conditions are caused by excessive speed and/or inadequate traction. If you're close to needing new treads for your 80, this could be a great opportunity to put on new treads. The bestest ever full-time 4wd system will not help if you can't grip at the wheels. Once you get onto gnarly icy roads in Colorado (if that happens at all), traffic crawls slow enough that speed is generally not a factor.
Other than that, as mentioned, properly functioning windshield wipers and anti-freeze fortified windshield washer fluid are really good bets.
Unless you're headed up towards Northwestern Colorado, it's not generally cold enough to worry about a gas engine needing an engine block heater.
Watch the weather in ND for the next couple days. You'll see just what you can expect. :)
Nice blizzard on its way tomorrow. 8-12" of snow and 40mph winds. Oh and don't forget -15F temps just to let you know you're still alive. At least for 20 minutes or so til you freeze to death.
We do have good ice already for ice fishing though. Bring it on! :)
More so for just winter safety, not so much 80 specific, but have a survival kit with you. I don't know if any safety kits specifically mention this, but I always have a pair of ski goggles as part of my survival kit. All the winter gear means squat if it's 30 below with 40 mph wind if your eyes freeze shut when/if you have to walk for help. (I know, stay with the truck, but sometimes that's just not an option.)
Also a bunch of those air activated charcoal heater packs. Damn those things get hot and last for hours. Life savers.
Most people just tuck it up and zip tie it behind the bumper out of sight. It is a god idea to make some sort of "reminder" device that you could leave on the steering wheel so you don't forget to unplug if you are in a hurry.
A note on the speed/icy conditions:
What tire pressure is good for this type of drving? I normally roll with 40PSI in the Cooper SST's and was considering boosting it to 45PSI for the road trip. However, would a lower pressure like the factory spec be better for icy roads?
