I got plates from SOR to replace my hinges while I figure out how to fix them since I can’t find any replacement hinges. They say they fit but one of the bolt holes isn’t even close, ha anybody else seen this?
Try loosen all of them up and get them started. If they are too far off you may have to enlarge the holes slightly. I replaced my hinges with some that where in much better condition and had the same issueI got plates from SOR to replace my hinges while I figure out how to fix them since I can’t find any replacement hinges. They say they fit but one of the bolt holes isn’t even close, ha anybody else seen this?
already did that, i may drill them out, these are just temporary until I figure out how to get the broken pin out. I may just leave it with 6 bolts instead of 8 for now. I had to weld bolts onto 9 of the 16 holding the hinges on.Try loosen all of them up and get them started. If they are too far off you may have to enlarge the holes slightly. I replaced my hinges with some that where in much better condition and had the same issue
Use an air hammer on those pins, they will pop out. Drilling them is almost impossibleSame on drivers side too
They are made left and right. And if 7 out of 8 bolts fit flipping is unlikelyDid you try the plates on opposite side? Could be the holes aren't symmetrical top to bottom and swapping them may allow holes to line up.
Loosen up all the bolts and raise the windshield a bit. You may have to enlarge some of the holes on the plate. Aftermarket parts tend to not be perfect.
I tried with a pry bar and couldn't get enough movement, I am just going to leave it like this until I can repair the hinge that I took off. this was mostly to make sure the windshield wouldn't be misaligned or stressed when I put the new soft top on when it comes in.I think this is your answer. I just went out and checked the gap and I was able to get a 1/4" transfer punch between the cowl and windshield. If your gap is smaller loosening the bolts and raising the windshield slight might get you there without opening up any holes.
