Winch advice
looking to finally get the winch...need some input please
as far as driving habits...don't do any mudbogging, usually just trailriding and not hitting the hard stuff or rockcrawling too much, live in snow country...i will be using it to winch my driftboat up and down a few steep put-ins, no stump pulling in the near future
most are telling me the 8,000 lb. warn would do the job. my rig does already have the arb winch mount bumper
thanks!
An 8K winch will be fine to pull you out of some minor scrapes. Be sure to get a snatch block (pulley that allows you to double back the cable to your rig and double your winch capacity It has a 1000 other uses, also). If you're looking to do some serious winching, you should prolly go 12K. I'm keeping my eye out for a good deal on a hydraulic winch. By the way, there's good info if you use the search function on this site. HTH
thanks for steering me in the right direction...looks like the 8,000 lb. will do the trick
Superwinch EP9.0 :)
https://forum.ih8mud.com/winching-recovery/239283-witch-wench-wood-you-choose-post3627563.html
About $45 bucks more than a Warn M8k, but it comes with a submersible Albright noid pack, a much better clutch handle design and a quality 20K Snatchblock :cool: (the snatchblock alone is over $100 bucks)
Superwinch EP9.0 :)
X2
IMHO this is the best winch for the $$ its better than the warns in its class at double the cost. I have used this on one of my 80's and i have used the warn 9.5XD and 12000,I never had a problem with the 9000lbs capacity in pulling anything from a bad spot ,But it was not a loaded down 80 like some here have and they may need a larger winch for there aplication,the M12000 is slow on line speed..
I have sold more super winch EP9000 AND EPI9000 than any other winch we sale.
Mile Marker, Super Winch, Warn, etc...tough choices. Does anyone know what Mile Marker, Super Winch, and Warn winches will fit in an ARB and a Slee Short Bus? I know the ARB will take the Warn 9, 9.5, and M12000 and the Short Bus is designed for the Warn 9 and 9.5...but, what else has anyone managed to squeeze in from the other manufacturers?
For Mile Marker users...did you upgrade the power steering pump with an after market (more robust) pump?
Cheers.
- Mark
There is no substitute for common sense (AKA good judgment). A 12K winch is not, lockers are not, 4WD is not! My point is: if you go looking for trouble, it doesn't matter what weapons you have with you. Sooner or later you're going to meet your match! I agree that you want to be prepared. The question is: how much $$$ do you want to spend to match that ego? Also, how do I define fun? If getting stuck on purpose falls into that catagory, than hell yes, get the 12k! Now I'm not saying that common sense will guarantee that you never get stuck or never have problems. All I'm saying is a lot of our problems, especially in wheeling, are self inflicted. I know, I'm going to catch hell for this from some of you but, think about it, and be honest with yourself. The last big stuck you were in - was it avoidable. Prolly. Could you have gone around or turned around? Prolly. Was it life or death or even necessary to be where you were? No, prolly not. If you're on Search and Rescue, you definitely want at least the 12K. Having a winch and the knowledge of how to use it safely and effectively I think, is more important in most situations than having the biggest winch that your rig can carry. Now, those of you that have the bigger winches, good for you. When and if you need more pulling power, you have it! Myself, I just cant justify the extra $$$ and weight to make it a necessary mod. My 20+ year old 8K Ramsey works just fine and gives me peace of mind.
you all have hit the nail on the head...you are right on with your reply 80t0ylc...
i have yet to have needed a winch myself since i have been 4x4ing since i got my licence to drive 20 years ago...i have been pretty cautious and i am quite conservative, some of my other friends are not and i have had to help them out a number of times...not to say i haven't done some dumb stuff in the past or will in the future...no bravado here!
i agree that is better to have too much than not enough, especially when it comes to recovery...but i think it is going to narrow between the warn 8k and the superminch 9k
thanks!
Good points, but all stucks are avoidable by sitting in your driveway. However when I go out in the woods I really like to be prepared. People make errors in judgement all the time. Weather changes all the time. Terrain changes all the time. Parts fail and trucks (even LCs) break. We all know this.
Fact is, no matter how careful you intend to be and no matter how much common sense you have and use, unforseen situations always arise. What we do is not what I would consider "safe".
I feel very strongly that recovery gear should be designed, not for the 99% of use, but rather that narrow 1% margin of "what if". It's just how I roll.
WHAT TIMING!!!
i guy i work with has a like new warn 9500HS...will this fit in the arb winch mount bumper?
WHAT TIMING!!!
Most High speed and XD style winches have a longer motor or end caps with cooling fins these can come in contact with the ARB where it tapers back on each side of the winch,You may need to use a spacer to get the clearance you need if it contacts the bumper , The I series will lay flat and work fine in the ARB..
