You know how every once in a while someone gets on and asks a
question? Well here comes another. This has been driving me nutz for a couple days but i am certain there is a good reason people arent doing it.
The Conversation has gone on for a long time about a diaphram style clutch will or will not work with a yota 4 or 3 speed. It has been stated that you must use a centerforce clutch which is sweet but the negatives are cost and a sore leg. So..... It is always the same problem or reason why it will not work which is that the slave cylinder doesnt have enough throw to fully disengage the clutch.......But people always get on and say they are doing it right now so my guess would be you possibly need good non wore parts to squeek the tolerances. I am certain the issue must be partially true being that Advanced Adapters and Downey himself state that it shouldn't be done (no disrespect intended with this Downey!!)
So my question is since it is obviously very close to working and some times does why couldn't you shim the pivot ball out a little gaining that little needed bit? Being that it is on a pivot a little shim should mean a lot??? (sorry not scentific language)
Here is a pic I stole from some one else while i was searching for this topic rather than just trying to look stupid for no reason
You can see this gentlemans problem his pivot ball wasnt in the indention in the fork....
I mostly have been searching 350 conversions in general. I was searching for a flywheel a second ago @ Jeggs and found this thin spacer that goes between the crank flange and the flywheel:
Oh and i am still in favor of the shimmed pivot ball if it would work rather than this flywheel spacer
because i was one of the unlucky ones......
Hope it works in any case
