- Joined
- Mar 27, 2003
- Threads
- 70
- Messages
- 1,059
I replaced the original LX450 suspension last year with a stock height OME kit (springs, shocks and damper). I also replaced the "rods" and TREs with the Slee after market stuff and had an alignment done. Unfortunately, no printout but I still found the steering a bit vague, suggesting too little caster (from what I've read).
Fast forward just over a year. I just replaced all of my tires (stock size) and the guy told me the TREs on the tie rod were completely shot and dangerous (he was right).
So, just back from the dealer with new Toyota TREs, some brake work and alignment. The truck is basically stock:
- stock tire size (Goodyear Fontera "Triple Treads")
- OME stock height suspension, maybe +1.0 - 1.5"
- Weighted down a bit with gear, but no bumpers, sliders, winches, etc
The dealer printout shows that the Toe is within specs, but both the caster and camber are out of spec:
Caster is showing 0.8* (left) and 0.4* (R) (2 - 4* is spec)
Camber -0.1* for both L and R (0.3 - 1.8* is spec)
Any thoughts on why with a 'stock' set-up this is all wrong? I still find the steering too light. I guess I could go with OME caster bushings to add caster? Maybe the old ones are worn out (any way to test this) and stick with OEM?
Thanks for your help!
Cheers, Hugh
Cheers, Hugh
