- Thread starter
- #81
Don't think I'd keep the sway's off if I had a typical tricked-out 80. Too top heavy. Without all the added weight of those accessories the lean is actually pretty mild.
AMMO said:... thanks to some fellow 4x4's and a strap I got up this hill OK. Body lean is noticeable in this shot...
-Ammo
AZcruiser said:John,
you going up to Powerline again on the 26th with the AZLCA club?
reffug said:A brave/stupid one.![]()
ShottsUZJ100 said:Probably a 100? ;p
alia176 said:What kind of a vehicle was helping you out?
AMMO said:I This is a hill I’ve climbed before, just with all the storms and rain/snow it made it slick. I didn't lock, I didn't air down, I wasn't thinking... It was like someone threw sand on concrete, wheels just spun, and got me sideways.
-Ammo
concretejungle said:I had a vision last night, sorry if this is allready in effect. But i was thinking that if you took the control arms that slee sells for his 6 inch lift and installed an adjustable joint (the kind for the adjustable panhard rods, you know the kind that screw in) on the control arm. THis would do two things; 1. Allow for lenghtening or shortening of the control arm if needed for caster, and 2. allow for central pivot of the arm during flexing. It would still be super strong, but as the axle articulated and the control arms start to bind on the bushings, the joint would simply pivot or screw a little and allow full flex of the axle without binding on the bushings.
expeditionswest said:John,
I would leave the 80 alone after removing the swaybar. Longer shocks in custom mounts will allow for greater extension travel, but you will need to address bushing restriction before any appreciable gains in crossed axle articulation will be made.
expeditionswest said:I would suggest leaving the extreme fabrication to those who can also service those modifications on the trail.
Everyone here knows how a match-up between a STOCK 80 and a STOCK Rubicon would fair...
sleeoffroad said:Not true, with longer shocks and the rear of the suspension stock, I got about double the articulation with the shortbus vs a stock 80. Sheetmetal got in the way a little![]()
Who cares? It’s not about flexibility, it’s about completing the task.expeditionswest said:Without major modifications your 80 will never have the flexibility of the quadra coil Jeep suspensions. Stock to Stock, the Jeep suspension allows much greater flex by design. Anyone that tells you that an 80 with the swaybar disconnected using stock suspension components will flex as much as a stock coiled Jeep is delusional. I fear that many on this board view reality through TLC colored glasses...
½ right there crackboy. … continued on nextexpeditionswest said:The reasons to own a Cruiser is not have greater capability than a Jeep Wrangler
Yes, it is more expensive to wheel an 80 that a jeep. Not sure though in the long run if it’s more expensive after the tough run. You’ll spend a lot of cash fixing your broken bits as we air up and cruiser home. It’s also not only climbs but offcamber situations etc. It depends on the trail. I’ve been up plenty of trails where 40s could not go and they have been up trails where I can’t go.expeditionswest said:I am often amazed at how hard people work to try an fit a square peg in a round hole. I guess chock it up being brand centered, even if it takes 3 times the effort and expense to come to the same result.
Yes, you are right. You would be sitting there trying to rebuild and holding up the line so the folks in the 80 would be bored out of their minds. Been there done that.expeditionswest said:Everyone here knows how a match-up between a STOCK 80 and a STOCK Rubicon would fair...
Actually it sounds as if your view of the world is more intuitive than empirical.expeditionswest said:I am sure I will receive some interesting responses to my comments. Hopefully they will be more empirical than emotional (as seems to be the trend...)
sleeoffroad said:We used to make the arms with just such a joint. It allowed for reduced stress on the arms during flex, however it can not be used to change caster. Also, the joints were very difficult to machine. Needed very close tollerances as to not have slop in the arm. Then after you machined it the tube had to be bent. This could cause the threaded end to slightly deform and then you are hosed and start over again.
In the end, cost won over advantages. However if you 3 link the front and deal with straight arms, then it is quite doable.
I would leave the 80 alone after removing the swaybar. Longer shocks in custom mounts will allow for greater extension travel, but you will need to address bushing restriction before any appreciable gains in crossed axle articulation will be made. Your 80 works awesome as is. By making major changes to the stock systems you are introducing too many variables to long term reliability and serviceability (IMO). I would suggest leaving the extreme fabrication to those who can also service those modifications on the trail.
The reasons to own a Cruiser is not have greater capability than a Jeep Wrangler (which it does not, unless it is a pure WB climb), but to own a vehicle with superior durability and reliability. I drive a Jeep on the difficult trails because that is the BEST solution for that terrain (so is an FJ40, defender, etc.), which is the same reason why I drive a TOYOTA thousands of miles into Mexico, because that is what a Tacoma/80/100 is best at. I am often amazed at how hard people work to try an fit a square peg in a round hole. I guess chock it up being brand centered, even if it takes 3 times the effort and expense to come to the same result.
