Clutch stays. I will try to load the part that makes the difference. Without this the drive shafts need to be worked on. This adapter is where the 5th gear is housed also attaches to the TC.
Sloan said:Can you get the H55F and the transfer case both new from the dealer? Toyota of Santa Monica sends me 20% off coupons for "parts" every once in awhile.
Sloan said:is it possible to use the transfer case that is on the 60 now?
Sloan said:BM when you go to put that sucker in let me know if you want some help. I'm up in LA and after this week I go back to weekends only off. Let me know because doing it myself would save some coin.![]()
photogod said:Clutch stays. I will try to load the part that makes the difference. Without this the drive shafts need to be worked on. This adapter is where the 5th gear is housed also attaches to the TC.
pasnkhunter said:Got mine from cruiserparts.net ($1850 shipped to me). They included the 5th gear oiler and cap for the shifter! You will see where the oiler fits on the trans. side of the transfercase, snaps in.
pasnkhunter said:The hole, I just tapped to 7/16 fine thread and red locktited a short bolt in.
pasnkhunter said:My h55 is in a converted 89 fj62. Was a little more complicated to install but still not hard. Will be a simple bolt in for 85-87, with no mods to drive shafts. I'm runnin 4.56's with 35in. general m/t's, Great low end for wheeling and cruise at 70-75mph at 3000 to 3200 rpm. Great upgrade!
The H55F uses a different shifting mechanism on the top of the tranny than the H42 so it comes complete. Some have reused the 4spd shifter by forcing the round bushing onto the shifter end. I can see how it would work, kinda. But the H55F shift end has a ROUND end with the bushing fitted over it. With all that other expense get the 5spd shifter and use it as Toyota intended...Boston Mangler said:for those of you that bought these from vendors or dealers, did they come with the top shifter plate, or is the 4spd one reused?
thanks
