which bushings?
Kl2
Hawaii
Guys my rig supposedly has a 6 inch lift, i measured one day from center of axle to top of fender and it was 5 1/2 over stock. Anyway the rear control arm bushings are ripped up and it looks like all of them are quite ready to be replaced.
my rig is primarily used for wheeling, hunting and camping, not a commuter by any means.
what brands of bushings should i be looking at?
should i be running caster correction in the front?
what am i not asking?
thanks in advance!
OEM bushings are very durable and long lasting. Your purposes won't be calling for any flexibility beyond which an OEM bushing can provide as axle articulation is limited mostly by the radius arm suspension design. Actually, the oem's have small voids in them so they will flex pretty good anyway.
I crawl rocks regularly and feel the oem's work well and no one has ever reported problems with them. I just ordered OEM bushings for my front radius arms as they are the only original ones left on my rig.
Agreed on the OEM bushings. I've seen a few posts in which non oem bushings (moog, TJM, etc.) didn't hold up well with frequent wheeling. do you know what kind of lift it is? if you don't have caster correction in the front, i'd go with the slee or landtank caster correction plates. although with the amount of lift you have, might be better to get the radius arms offered in the slee kit (lots more $ though).
  • Like
Reactions: Kl2
Thanks guys, I have never before owned a vehicle that oem is better ! I don't know what brand it is, the po claimed it's ome, but I didn't find a 6 inch on their website.
The truck seems to ride straight so they may have put in new radius arms when it was lifted
Generally speaking OEM is the way to go on most but not all the wear items on an 80.
thanks in advance!
@Kl2
My opinion is YES. Castor correction is so very nice to drive once corrected. I went along time without. I went with the IronMan as it had a bit more degree of correction than MetalTechs version.
@Kl2
With his lift, plates for sure and yes may need a bit more. The MT plates I'm pretty sure Mark told me were designed around the OME J lift (built based on their old 80). Running the "J' lift the MT plates fit my bill well.
I would say you need to figure out what you already have?
For a 6" lift you should definitely have some type of caster correction already. I would assume caster plates as the bushings only give so much correction. If you don't have the plates and do need something. I would do OEM bushings and caster plates.
But you probably have a DC driveshaft as well. Since it would probably vibe pretty bad without one.
^^^^ This
  • Like
Reactions: Kl2
Thanks guys, I'll crawl under tomorrow if it's not pouring and try to figure out what has been done and post back
Pictures of the radius arms would help identify whether they are stock or aftermarket that may have additional caster built in. Color of old bushings may also help with ID. Bushing centers may vary on how far off center they are to provide various degrees of correction.
