I need (well, lets be honest i want) a 5 speed for my DD 86. It has a carbed 22r and a 4 speed which i believe means that i need a g series trans. Does anybody know of some toyota yards or retailers preferably on the east coast where i could procure one. Im hoping that there is a company like cruiserparts out there except for minis. I know there are places like cal mini in cali but i dont think i want to ship a tranny cross-country.
I'm gonna go out on a limb here and say...
If you can find any 5speed that went behind a 20r(ixneigh on the 20r trannys), 22r or 22RE, you should be able to eyeball if it'll fit or not. And I''m 99% sure they all will.
The bad part about all this is, you'll only be getting a whopping
500rpms a minute off the motor you have now.
It's not a substantial amount, but it is some, and it is free. (what I call when you
have the option)
Also, am i correct in thinking that a R series trans will not bolt up without some kind a new bellhousing or bellhousing surgery?
-Matt
At the least, you'll need to replace the BH. At the most,
I have forgot if the BH is just a "bolt on" or if you have to replace the front half of the case along with it, b/c the BH bolt pattern may or may not be the same as the front half of the case that accepts it....I don't remember. But I think all you need is the bell housing.
If you can find a 2WD RTE it will be the HD V6 tranny, only it wont have the low 1st gear and
the speedo cable is on the OTHER side. Making it a ROYAL P.I.T.A. You either have to pull the dash and replace the cable, or fab-up some type of extension. Been dare, done dat.
