Fwiw- No fuel injector issues with either one of my 100s and i don’t use any fuel additives. Both over 250k miles now.
Let me go unplug and go for a short drive. I’ll report backTypically we pull wires off injector while engine running. RPM should drop. If not, can be fault in wires or bad injector.
If felt better with FI disconnected. Very likely bad injector. They do go bad. Try driving around, with FI disconnected. You'll have slight loss of power. But it should smooth out, if bad injector.
Note: If vehicle sat parked for prolonged periods. This can (not will) result in rust on FI needle.
Did you check the driver side of the connector for a good pulse? A test light or noid light works for this test.
I know you mentioned that compression at #6 is 150 psi, did you do all cylinders?
No change, at this point. Indicates Fuel Injector issue.Didn’t even make it out of the garage. No change in driving. Truck is shaking. I did unplug and plug in the injector while running with zero affect
Good point/test, and should be done before R&R of FI.Did you check the driver side of the connector for a good pulse? A test light or noid light works for this test.
A test of all 8 cylinders, is best. 150 PSI is weak, but enough for combustion and shows rings & valves sealing well enough.I know you mentioned that compression at #6 is 150 psi, did you do all cylinders?
Once your sure you've good current to FI. Either just replace that one FI or pull and test on the bench.
But was it done by the book. Which is hot engine, fuel cut off, T-body open and at 250RPM. If liquid in cylinder we get high PSI reading.
Did spark plug look normal and same as other more or less.
But for now I'd move on to R&R that FI. Assuming you did check spark. i.e.
But for now I'd move on to R&R that FI. Assuming you did check spark. i.e. View attachment 4209907
Don't worry about it. Cold engine we do see 150PSI. You have compression.The test was performed when the engine was warm, not hot.
Good!The spark plug, and coil looked totally normal, and no different than the other cylinders. The truck ran fine prior to this event,
STOP. OH----Once in a blue moon P0306???despite having a P0306 every blue moon as a pending code.
I've seen from no difference to as much as 40PSI. You have compression 150PSI, move on for now.I have always wondered about the fuel injector condition on this engine, since it has 307K and no prior history of the FI being serviced/replaced.
How much of a difference would a cool engine make verse a hot engine?
Warm is good enough for now. If doing a compression test later. Then get up to norm op temp, and all 8 sparks plugs out. Check them all. And low check wet.
Since you did hear #6 FI. That's a good indicator wires good. Also FI not dead.
Do check spark, if good. Next check for misfires.
Then if all good. Pull and test or R&R that #6 FI.
Good!
Swap coils, may or may not show a coil misfiring. Check for misfire. They fool many.
