wheel size and back spacing
the stock backspacing on a 40 is 3.5" . when I did my spring over I got my steering arms bent up to clear the springs so stock back spacing wouldn't work. So went with a 2.5" and I like it. is not too far out but it still looks good.
Summit Racing has some unpainted wheels (with whatever backspacing you want) for about $40.
link
- Rico.
theo said:
Maybe irrelevant, but the backspacing on my '86 4Runner wheels is 4 3/4". Too deep without thick spacers.
86 and up 4Runners are IFS. He's talking about 85 and before - the years with solid axles.
8" rims with a 12.5" tire would be pushing it a little. I run 33x10.50 boggers on the stock 15x7 on my fj40, and it's ok, but not ideal. I have to be real careful airing down to less than 15 psi, and can't go below 12psi or it will pop a bead during turns every time. I used to run 32x11.50 on a 15x8 on a bronco I had, and again it was ok, but any wider and I would have prefered a 15x10. An 8" would work, but 10" would be better.
Here's a link to a backspacing table for fj40/60/80. I can make no claim to the accuracy- I just found it a couple days ago. However, I think it's a pretty good guideline.
http://www.mindspring.com/~lfry/wheel.htm
really? i thought 8 would be best for 12.50, holds the bead better than a 10 inch
Before I went minitruck FDB I had clearance issues with my 15X10 MT Classic II wheels on 33X12.50X15 tires. Had to use 1/4" spacers to get the required 3.5" backspacing. When I did the FDB, my 75/08 FJ40 received 79 minitruck donor parts. The minitruck steering arms must have a different bend than the drum-brake 40's as the spacers are no longer required using the same rims. Added benefit I didn't count on. Kinda makes up for the extra money it cost that I didn't buget!!
8 or 10" wide wheels will work with 33's. You will get plusses and minuses on both, just like a 2F/350 or a SOA C&T debate. Only you can decide which is best for you.
