What's this wire?
MrMoMo
That's not rust, it's Canadian patina...
~Kingston, ON, pero soñando de Panamá
Poking around under the hood on my '76 40 and found these wires by the coil. Can anyone tell me what they are/were for? Everything seems to be running fine. What was/is this - my elusive fuel economy microcomputer connection?
I was poking around for a place to put my "anti-theft". Trying to decide which would be better - cut the starter signal wire, or cut the coil ground/power wire. Figure that the starter is safer (i.e. if my mod craps out I can bump start in emergency - but if my mod craps out to the coil, she ain't gonna run...) But the coil would be much more frustrating for a theif...Crank crank crank crank crank.....any thoughts?
They look pretty factory to me, they go right into the harness. There is also a wire going to the (-) side of the coil that goes into the harness, as well as the one I put in for the tach... Nothing on the opposide small pole of the coil (+?)
On a 76 cruiser [which is what I'm gonna assume we're dealing with here] there were several wires around the coil having to do with the ignitor assembly. One of them had a bullet connector like in your pic. There was some kind of condensor attached to it, which in turn when to ground. I don't remember where exactly it hooked up on the coil/ignitor.
If ist's a 76 where is your igniter? Thats definetly not a stock setup so it would be hard to say what that wire is for but I'm going to gues tach. Though that wasn't stock either in 76. lol
76
I think I know what you are talking about...There's something like that on my '79. It may be noise suppression for the radio, to reduce ignition noise.
Gundy said:
I don't know the dates for change and such, but my
72 has a ballast resister attached to the coil.
That's the purpose of this "mod"... you are bypassing the resistor during cranking so you get a hotter spark to get it cranked faster.
Oh, and another question, it's a dec. '76, so do I go by the '76 or '77 wiring diagrams? - truck runs and starts fine without whatever was there.
Gundy said:
What "mod" are you referring to? Do you mean just disconnecting the resister?
Wiring the "extra" wire from the starter to the '+' terminal of the coil.
That's what we have been talking about...
largenfirm said:
In a completely different thread, which the readers of this thread may or may not be reading:
https://forum.ih8mud.com/showthread.php?t=66671
HTH
Kirk
Actually, I started that thread...
That was one of the reasons I started this thread, to tell people what I figured out later, that helped fix the problem
excuse me
I am not a subscriber to the old thread and obviously not among
the 'we".
I'll go read the other thread. For now....'excuse me whilst I catch up.
Sorry for any confusion caused.
Edit: I read the above linked thread. I am completely lost. It happens often.
The link is to slow starting Webber issues which were fixed. I think.
Mine is a one pump start with a 38dgs and electric choke with an electric fuel pump.
I thought MrMoMo started THIS thread. I've lost it.
Forgive me. I'm out.
Good luck Mr MoMo and Rick '79 FJ40
Sorry I couldn't offer help.
That was one of the reasons I started this thread , to tell people what I figured out later, that helped fix the problem
WTF are you on dude? Look at the top of this thread and see who made the first post - it was me, not you - you didn't start this thread.
Time to put the crack pipe down!!
So, I believe I still have the ballast resistor in place, there is also a black wire (not indicated in picture) that looks like it would be a tach signal wire - but this is a bullet connector and open ring connector... If this is a mod for starting, do it because mine starts great.
QUOTE]
Sorry, I started a thread about connecting a wire from the extra wire on the starter to the coil that helped my starting problem. I didn't realize that this wasn't that thread when I got the email about replies and thought I was replying in that thread...
My mistake.... BTW, do you know where I can find some more crack?:o
I'm Rick James, B*tch!!! Sorry....Crack + Rick= had to. :)
I've heard Junks momma has some, although I'm not sure it's the type you are looking for.
