I wasn't sure where to post this, 40/55 Tech, 60 series, or here. So, I'll start here.
I currently have a 75 FJ55 and would really like to have a 5 spd. I am also considering buying an FJ60.
Does anyone have experience with swapping an H55F 5 spd transmission into both an FJ55 and a pre-85 FJ60? Can you tell me which one is less difficult, in your opinion? From what I've read in doing a little research, they both sound like they have their challenges. The H55F into a post-85 FJ60 sounds like a pretty straight forward bolt on, so I already know that would be an easier option.
Thanks.
Thanks.
, and time and $$ are more limited.
Yes, if you swap a H55 you have to use a split case and you loose the transfer case mounted ebrake. This leaves you two options, pay out the nose for a OEM split case ebrake setup from $OR or add a
