Whatcha workin on?
Ih8 sunroof problems!
Finally made a huge leap forward on centered axle project. Found a guy in Leland, IL selling an fj60 3rd.
My axle width guessing was pretty spot on!
My wms will be about 59.5”. I was planning around 60” for the front.
After an obscene amount of figuring, part finding, painting, and work , I got oem flares mounted on the HZJ-73. We took it to Newaygo for dinner and it ran flawlessly. This is supposed to be our summer daily driver, but it still needs some more things- thankfully it's really close!
And of course, I forgot to take a single picture today when we were out!
The sunroof in the 100 is stuck in the tilt up position. This can be a problem with age, lack of use and corrosion. I've romove the glass and poured penetrating oil to everything with the hope the linkage may freeup. The cables that drive the linkage are known to seize within the tubes due to corrosion and or dried lube.
What's odd is I knew of the problem and have avoided opening the sunroof or so I thought. Somehow I must have blindly fat fingered the switch.
Hope you got it fixed Ed - my 80 had a leaky sunroof, I disabled the switch and sealed outside with 3M 5200 - bone dry since.
I finally got both of the slides into the down position but the mechanism is still not moving smoothly. Id like to get it functional but still remove the fuse.
These seats have been sitting in their boxes for almost 2 years. They were originally going to go in the 40 but we decided they would be better in the 73. I'd like to do a new console too, but not sure what. Other new bits are new steering wheel, clamshell, and door panels in progress. I have a vinyl front floor section but the mid section has been on back order for over a year. Gotta figure that one out.
Did some proper poser shots too!
Check out the thread that @kelly saad has going on @WarDamnEagle 's 55. That was a pretty nice 55 to start with but still has an epic amount of rebuild/fab/replace going on.
It's totally art. Will be the nicest 55 on the planet.
