Whatcha workin on?
I have not see the TRE E-locker before. I thought the Harrop/Eaton units were the only ones. Pretty cool.
the brand is newer in america, tony zepka out of wisconsin sells them, but theyre pretty big overseas. i talked to a bunch of youtubers from overseas who have used them for years, as well as some domestic nissan guys. a high quality copy of the eaton as i understand it. tre also has portal axles for a price thats too good to overlook..... might be on the list in a few years.
Nice 80 and from appearance well thought out mods
Thanks. I traded my olive FJ-40 for it. I think the deal was just about spot on. The 80 is a really good truck as it sits but I am hoping to do a lot of little detail items to it to try to make it super nice.
Yeah, they're called the Mullins Station Limestone Mine. It's a really cool spot!
-Rob
i thought those closed! exciting to hear its still open, i had thought about checking it out on my way down to leatherwood.
looks like a great time. will you ever do a canopy for the tray? Jeremy over at NHO has built some really cool ones.
Missed this yesterday.
I do have a canopy for the tray. I had it installed and loaded for my last trip to the DBBB, but it's just too much weight for the current wheelbase. It was pulling a wheelie every time I went up a hill. I have plans to extend the wheelbase 20" with a stretched 80 series frame, and extend the tray another 12". I have the parts to do it, but haven't tore into it yet.
-Rob
-Rob
I was wondering how that could be when that truck had all that firefighting gear on the back, but then I remembered they probably had a ton of gear hanging off the front too. If you stretch it, can you get or make the sheetmetal filler for the wheel opening like they use on the 4 door 70 series trucks?
So stock, the truck sat really low and had dump truck weight springs out back. I know the 75 series Fire Trucks had a steel counter weight bolted in behind the front bumper, I'm not sure if the 62's had that as well (bumper was swapped when I bought it).
I do plan to fill in that cab corner. I've found a couple examples over the years of it being done.
This one is pretty slick with a storage door. I don't think I'd go that route, since I'll be building out a flat, wide floor in the back, completely removing the wheel arches.
That's super cool. It will be a dream truck when you get through with it. Or I should say, even more of a dream truck, lol.
My son and I were called up to active Duty. So when I can I’m playing with this project.
The machine shop lead in my squadron turned down the axle flanges for 1st gen taco front rotors to slip over.
Months ago I picked up a 1st gen taco rear to scavenge the axle shafts from for my hybrid centered rear 40 axle.
This weekend while on break from my base I pulled them and a buddy helped me press off the old bearings and backing plates.
I spent some time grabbing dimensions from axle housing ends, brake calipers etc so I can draw up some caliper brackets to have cut.
I’m gunna widen early 12+8 mini truck calipers to work with 1st gen taco vented rotors. I’ll share pics later when I can.
When it’s done it will be a standard 9.5” center chunk, centered to work with an Np205 tcase with a 60.5” wms.
I need to finish my caliper brackets, prep the early MT tubes and stuff them into the 40 housing.
Played a bit with the caliper spacing. I’ll use 3/8” or 10mm plate to make the spacers from.
I’m using the solid rotor calipers intentionally so I can get a spacer and another o-ring in the sammich. 1st gen taco rotors fit nicely!
Got all of the alignment set screws installed in the fj40 center housing. Once the housing ends are trued and tacked, I'll pull the screws and weld the holes.
Between times of prepping and planting taters I also got the tubes stuffed together.
The sunroof in the 100 is stuck in the tilt up position. This can be a problem with age, lack of use and corrosion. I've romove the glass and poured penetrating oil to everything with the hope the linkage may freeup. The cables that drive the linkage are known to seize within the tubes due to corrosion and or dried lube.
What's odd is I knew of the problem and have avoided opening the sunroof or so I thought. Somehow I must have blindly fat fingered the switch.
I never knew that was a problem on the 100.
Kind of like pulling the e brake on an unknown vehicle from the rust belt!
Hope it isn't too bad to fix
It's a problem, Toyota used a lithium grease that dries out and turn to powdery paste plus the drain lines can clog. Worse case is having to drop the headliner to replace parts. Mine isn't horribly corroded.
