Is there a FAQ re: birfields, locking hubs, wheel hubs, and rotors? It took me a long time to figure it out for my DB conversion, and my lack of understanding resulted in my having to purchase some duplicate parts. Here is what I believe to be correct:
Birfields:
Coarse (10?) spline 69 thru 75, fine (27?) spline thereafter. Birfield stub axle length reduce by about 3/8" starting in 1979, so 76-78 are oddball longer disk brake birfs. FJ60, 79+ FJ40, and mini truck birfs are interchangeable. Shorter birfs are stronger and slightly larger in diameter than the 69-75 birfs, however a 69-75 axle housing can be easily clearanced for the larger diameter.
Locking hubs:
came in different spline counts and body heights to match certain birfields. the 3/8" shorter birfs can be used with the longer locking hubs by using a washer and bolt to retain the end of the stub axle instead of the C-clip. However, the longer birfs cannot be used with the shorter locking hubs.
Spindles: All Disl brake FJ40, FJ60, and solid axle Mini spindles are interchangeable.
Wheel hubs and rotors: 76-78 Fj40 rotor bolted to hub; 79+ fj40, Fh60, Solid axle Mini rotor attaches to wheel hub with wheel studs. The rotor/wheel hub assemblies are interchangeable as a set. The later (wheel studs thru rotor) rotors are considerably cheaper than the earlier bolt on versions, however, they are more work and expense to change out because wheel lugs have to be removed and replaced, typically with a press. Mini rotors are not vented, but 4runner rotors are.
Thats all I have time for now.
