1974 Fj40 was running great last week.It does not smoke or burn oil.The oil pressure (by the gauge) is high.I put on a '79 ignitor and dizzy.It also has a SOR two piece header.I used the two Fel-Pro gaskets when I put it on.The carb was rebuild by Jim C. last summer.I have noticed some knocking from the engine,and adjusted the valves.The knock is still there.It seems to have plenty of power and goes right down the road with no problems.I started it up yesterday,and I can't keep it running.I'm getting some backfiring when I let off on the gas.The engine is not running smooth at all,and when I take my foot of the gas,it dies.Adjusting the carb makes no difference at all.I checked the idle solenoid,and I hear the "click"when I turn the key.The vacuum is holding steady at 12. I checked the compression tonight and came up with this:
Dry Wet
1 136 140
2 130 150
3 139 175
4 137 160
5 135 175
6 131 198
The motor was cooling down,as it's about 30 degress here,when I was checking the compression wet.
Do I rebuild,go with the 2F motor,or V8? A friend of mine has about 18 of these trucks sitting around,and I'm pretty sure there's a 77 or 78 motor there.
Thanks for any info!
Bob
Dry Wet
1 136 140
2 130 150
3 139 175
4 137 160
5 135 175
6 131 198
Bob
The carb seems to run and idle fine for a while now,then I hit the gas,it loads up,then dies.
