What is wrong with this pic?
Medford, OR
All right to all you folks smarter than I am (which is pretty much everyone).
This is a picture of Nicolas' front axle. According to him, something in this picture is bent, but darned if I can see what it is. This occurred during the carnage when his sector shaft snapped and the vehicle went off the road.
He's on a very slow internet connection, so while I can ask for more pics, I may not be able to get them. Here's the e-mail that came with the picture:
Nicolas said:
Gabe,
They took the front part out, and i was suprised by how bended the part is. I first thought a smaller part was bended, but now i see what they mean. <I guess the language is a problem, and slow us down. Here is a pix. It´s bended backward on the passenger side. I'm now looking for a machine shop to try to straighten it. So far most people don't want to do it, but i cannot find the part anywhere, so i'll try
pushing.
I do see that the drivers side brackets for the control arm is slightly bent, but that's not enough to be a problem really. I'm guessing that it is the actual axle housing that is bent, but I wouldn't think just going off the road would have caused that.
Anyone with sharper eyes than me see any problems?
I'm definitely no expert, but is the housing to the left of the pumpkin bent back a little? Maybe the taper is making it look off to me.
The short side definitely looks bent to the rear of the pic (backwards).
x2 though it may just be an odd angle in the pic.
Good catch.
So possible scenario:
Sector shaft snaps.
Tires turn hard over passenger side (to the stops).
Vehicle swerves off the road, slams the driver side tire against an immovable object (log, rock, whatever).
Would that be enough force to bend the housing back like that?
More importantly....what can be done to fix it? Remember that these are mechanics without the proper tools availible (press, etc). What about cutting and welding it?
Any evidence of damage to the control arm? I'd say accident of some sort.
Can he run a reference line / plumb lines? That would be the first step.
I think that is camera distortion. Looking at his blog, he slid into a dirt embankment at low speed. It all looks very soft, and I don't see how a bent axle housing could result from that incident? But if it is a bent axle housing, he needs a replacement.
His blog post said the Toyota dealership refused to wrench on a US vehicle for political reasons so he took it to an independent shop. The independent shop should be able to order parts thru the dealership, or have some access to a used part network. He's in a tough spot now. He is completely dependent on finding a mechanic who can put this back together for him, and no-one seems to be sure what is actually wrong.
It's possible to bend the housing without effecting the rest of the suspension. Happened to my brother's '96 when he wrecked it. Initial estimate said that the damage was only in the sheetmetal, so they approved repairing it. After they got all the bodywork and painting done, they sent it out for alignment, and found that the front housing was bent. Had to be replaced.
His insurance co told him if they had known that at the time of the initial estimate, they would have totalled it.
Can he get a pic looking down thru the bore of the housing? With the front diff installed?
I would go with a bent control arm before a bent housing.
Can't tell jack from that picture. Without being there and without the issue being obvious it's going to be difficult to diagnose this from the States.
I e-mailed him asking about the control arm.
The housing is bent. Not only does the picture indicate it, but he stated it as well in his e-mail.
The question is how to fix it. Would cutting and welding it tweak it back enough to let him get rolling again?
Just got an update:
Nicolas said:
One of the arm was bent, we changed it. not sure how these guys got the birfield out. i found this morning a machine shop where they will try the unbending. Should be done by tomorrow. Hopefully that will make it. STill didn´t find the part. If i do, supposed to cost $750...
So yes, the arm was bent but it was replaced.
$750 for a new axle housing? Ouch. Supply and demand, I suppose, but I think his repair budget is shot.
That poor guy has the worst luck ever.
That vehicle was poorly maintained to start with and now stuff that rarely ever happens, unless really wheeling it hard, keeps happening to him.
$750 for an OEM housing is very cheap actually...if that's what it in fact was.
EDIT: Ok, I'm not sure I am reading the email correctly: did they swap out the front control arm and the housing or just the arm and it was $750 or was the arm being bent back into shape.
When an arm bends, very rarely will the axle housing bend as well. It will just pull on the housing moving it back a bit. Ask me how I know.... :rolleyes:
I see the pumpkin housing and short axle lining up... meaning the long axle looks bent... (somewhere between the housing and middle of the long side)
I bent my control arm and got a new (used) one for $75 bucks froma fellow mudder. I had some new slee bushings pressed in and took to the alignment shop to get everything dialed back in. I had them measure the wheelbase just to make sure my housing was not bent. Everything checked out ok. I wish him luck.
Well...I think issue #1 here is if the axle housing being bent is even a question, why is it out of the truck?
And if it's not bent, looks like it's kinda too late, they appear to be prepping to swap out the housing or something else big like that...dunno what the wrenches he's dealing with are like, but 99% of all techs I've dealt with never admit to making errors. They are like doctors in that way, or really a lot of men.
So it goes like this, wrench says "bent housing," looks like the dude's gonna buy a housing whether or not he needed one.
But yeah, x2 on the poor fella's bad luck. Who breaks a sector shaft? I've never heard of such a thing? And I don't think that that could be attributed to neglect...how did it happen? Did he hit something?
If they replace the housing it's $750. It seems that unlocked 80's axles pop up for around that price for front and rear, of course that's up here and not there.....
The arm and housing is bent according to Nicolas. The arm they replaced. My guess is that they did not realize the housing was actually bent until they replaced the arm and it did not line up.
They will only charge him $75 if they do not replace the housing. I'm not sure if that's for the arm + bending the axle housing back, or just bending the axle housing back.
That assumes that your lines are correct. You could easily draw similar lines that show it's the passenger side that is bent. Nicolas clearly stated in his e-mail that he could visually see the passenger side was bent.
An impact to the tire can cause it. Mine twisted from a low speed impact when someone did a hit-and-run on me. It takes a surprisingly little amount of force to twist it.
If he had some previous damage to it (minor impact to the tire) it would be twisted which would have weakened it. Going through rough roads like he did could have weakened it further. Eventually you'll hit a bump, rut, etc and the jolt will just snap it.
Parallax error (camera optics distortion) and lighting anomalies make it virtually impossible to diagnose any kind of alignment problem via photographs, unless taken along the axis lines.
Sector shafts are known to break or twist in 80-series trucks when they're wheeled hard. In fact, there's a company that does a sector-shaft upgrade to a 100-series shaft, which fits in the 80 box but is bigger, stronger, and requires a new and beefier pitman arm.
