What is wrong with this pic?
In fact, there's a company that does a sector-shaft upgrade to a 100-series shaft, which fits in the 80 box but is bigger, stronger, and requires a new and beefier pitman arm.
Called American Toyota. :p
(It's an OEM part.)
Just hope UPS doesn't lose the pitman arm. :lol:
That assumes that your lines are correct. You could easily draw similar lines that show it's the passenger side that is bent. Nicolas clearly stated in his e-mail that he could visually see the passenger side was bent.
Here's a more detailed pic to show my thoughts: :meh:
Oh I understand what you are saying, I'm just pointing out that you can play with the lines to get it to show anything you want. It's essentially an optical illusion, one that's very effective because your eyes will see what you want to see, not what's really there.
Is it the drivers side that's bent....or the passengers side? Well, depending on your point of view it could be either. It's like those optical illusion pictures where you can see both the outside and inside of a box at the same time.
Keep in mind I am new at this LC stuff but has anyone ever just replaced there front axle housing with a narrowed Dana 44 High pinion or regular D44 axle housing. Seems it would take care of all the birfield problems.
Yep, you're right. No more birfield problems.
However, you'll likely be having some U-joint problems instead....
:grinpimp:
I have one in perfect shape, never off roaded, 132k from my 96. I swapped it for a locking axle about a year ago.
Can probably do 200.00 shipped.
Shipped to Honduras? :lol:
Probably wouldn't even get there, considering the mail system they got. :frown:
