North wind at 25, 8in of rain in 24hr, 40 degree temp difference in 24 hrs.I think you’re a few below the limit there, better head back out!![]()
I’ll take any I can get, limit or not.
Well.... the week started off pretty mundane. A little of this; a little of that.
I got the bug to install my U-bolt flip kits and to test-fit the new rear full float 70-series axle. To get the pinion angle close to where it was with the truck on the ground, I decided to lift up the front and rear using jack stands on the frame rails (butted up against the inner spring perches). This seemed reasonable enough... It went well - at first. I got it up on the stands and was able to get the same -1° angle that it had on the floor.
Seuper! Now to pull the tires and get to work!
The rear tires came off without drama - as you would expect.
The first front tire came off - no undue drama or surprises there...
However, as I pulled the last front tire off, the front of the frame rocketed into the air and came down with a gut wrenching crash.
I f***ing dropped my FJ40 - like, on the ground.
Who drops a FJ40?
Thankfully, my recent offerings of ritual wallet-sacrafice must have somehow appeased the 'Cruiser Gods. I got away with what literally amounts to the single dumbed thing I've ever let happen in my garage almost completely without a scratch anywhere. Through divine intervention, the only thing that touched the ground, somehow, were the U-Bolt plates.
Luckily, these two weren't in the garage when it happened:
I will leave this out of my memoirs.
Know the feeling except my jack stand fail was slow.
Had the back of my 60 Chevy wagon on stands while replacing the center bearing.
One of the cheap stands gave out and the car slowly started to slide over.
I was in my 20's then and could move faster than now so got out of the way in time but the good stand punched a small hole in the gas tank and about ten gallons of gas ran down the driveway.
Ever since then I leave floor jacks in place and throw tires underneath as well as the use of jack stands.
Glad your story does not include a hospital visit or worse.
Don't do it, Montana sucks! I had to drive through 8" of snow Saturday, today I'm chuckin dry flies to rising trout. Finicky bastards too.
Dries in October in Montana! What pattern and size? Lucky turd![]()
Who drops a FJ40?
96 BMW front seats and a Bestop Fold and tumble.
What year and vehicle are you putting those BMW seats in? How much taller than stock are they and how are you mounting them?
75’ 40. Previous owner installed the CCOT bestop kit and those came with adapter plates. The plate is pretty broad so you can mount any seat you want really. As for height these seats adjust in height, but were similar in height to the Bestop seats.
