- Joined
- Aug 14, 2012
- Threads
- 30
- Messages
- 558
Got rid of my Ranco 5000's and switched to KYB Excedy . Stamped on tube Made in Japan They look identical to stock and ride so much better than Rancho 5000's ride even better than stock.
Had a stroke of accidental genius tonight while chiseling away the remnants of the asphalt sound/heat insulation on my transmission hump.
If anyone has ever messed with this, you know it takes quite a bit of cheseling, heat, grinding, etc./QUOTE]
I tried a couple of different things, you are right, it can be a mess but then I found this magical stuff:
Much improved over the KYB shocks I had before. Drives and handles better. Takes rough spots on our gravel road better also.I thought I’d read you had... but couldn’t spot your post.
Follow up thoughts? I’m considering getting them one day, and would love to get some real world data would be appreciated. How is the ride?
Been running Rancho 5000 since they were the greatest thing since sliced bread.
Spent the week chasing gremlins...installed LED bulbs in all the tail lights, and when I engage the turn signals I get flashing brake lights in addition to turn signals. It all works fine with the original incandescent bulbs, but with LED bulbs only do I get this odd behavior.
Finally discovered this mess tucked away under a bracket in rear bumper. It was crudely tapped into the rear lighting harness. Removed all the taps, cleaned up harness and now it all works perfectly. LED lights are a very nice update...significantly brighter and safer
Out and about first time after some upgrades. TBI lift etc...
Running great!
What lift did you go with? HFS? It's a tough call between that and OME for me... Just curious - is there a reason you went with one vs. another or did it come down to price?
Boy does that look familiar! Funny thing is I had a second entire trailer harness wired into one of my tail lights too.
I had @Coolerman make me a real nice replacement rear harness since mine was pretty mangled. If that’s the route you’re taking I wouldn’t hesitate to recommend his work!
You are correct, this can be a messy job!! I tried different things--very frustrating until I found this magical stuff:
That's nice! Got a link for the setup?
