Just rolling the ball a little further each day.
The best thing I've done for my Cruiser yet- new shocks to replace the originals- which were of course shot.
I can not believe how much better this thing rides now. It takes bumps without throwing all my **** in the air. I don't have to slow down for those dips in the road as I did before. The terrible wheel balance issue that cam with my STA tires is significantly lessened. Its a whole new truck- highly recommended maintenance. If you are riding around on old shocks- Bilstein 5125's on all corners- you'll love the difference.
Pete
I changed the bell housing donut bushings.
Moe R said:Just rolling the ball a little further each day.
I have a set of those ready to install but I'm not quite sure the best way to get at them. Any advice?
Love the matching steering stabiliser Moe- wish I'd have thought of that when I painted my rig.
Just get under the car with a two 19mm wrenches and a 19mm socket ratchet wrench. Use the socket on the to and the wrench on the bottom on the passenger side. Easy as pie.
Drivers' side you have to get to the head which is inside the frame. You should be able to get just a little enough bite to loosen it up.
I put a 4x4 block of wood on my jack and lifted it from under the transmission. You will have to lift it quite a bit because the old bushing are smushed flat. Once you get the bushing in stick in the bolt to line everything up and set her down. reorient the drivers side bolt and put her together. Watch out because the bolts are different sizes.
