What have you done to your Land Cruiser this week?
Finished the 4 link & CO's & custom 7 gal aux rear tank.
Thats with a 55" wms axle, at full stuff the tires barely touch spring, with 2.5" backspace rims & 1" spacers ( I know, I know ), unavoidable & I wasnt into building a new axle thats wider just to delete wheel spacers which have been there for a decade.
Put a small wire wheel on the dremel and cleaned the oxidation off of the notched shaft behind the parking brake handle. Wadda you know, it moves a LOT easier.😊
Minor resto-mod this week. After "modernizing" the cabin light to turn on when I open the doors (build thread), I took advantage of the pressure-switches, repurposed an FJ40 seatbelt warning buzzer, and, well, here you go:
I mounted it using the top bolt of the emissions control computer (not sure why I haven't removed that, its literally unplugged), its powered by the corner / parking lights connector off the headlight switch (green wire on a '78). The ground is tied into the wire that connects the dome light to the ground via all the pressure switches on the doors.
I found out the hard way that when the headlight switch is completely off, it grounds the green wire to the corner lights (which in this configuration meant that both the buzzer and dome light turned on when the light switch was off and the door was closed :D, so I put a diode in-line between the headlight switch and the buzzer. Problem fixed!
Minor mod, but I did it for the karma... Im daily driving the truck and in the last month, I've forgotten to turn the lights off twice. It just so happens that in both cases, someone I knew was nearby, saw the truck, and found me to tell me. Figured the universe was telling me I was out of freebies ;)
Brilliant
I have had a ton of work around the house so I had about 30 minutes towards the end of the day to add some female spade connectors to the speaker wire and mount the speaker plates to the kick panels. I don’t really want to drill in the diagonal floor mounted holes so used these pull thru rubber feet to press into the floor while the plates are mounted on the pillar with two screws
Very cool mod
Finished the rear seat in Ol' Green for the grandkids.
