MatthewMcD
Thanks, I'll test this.My question was intended for @wchevron. If he's running a stk driveline then his numbers don't add up.
Matthew, how are you determining your speed? What size are your tires. Do you have a tach? It seems something is restricting your RPM or power.
Timing, Mechanical advance, valve adjustment, vacuum leak or maybe the carb. Suck on the vacuum canister hose and see if the canister holds vacuum. If you can suck air then its bad.
I assume this is the rear tires. I'll check this too.Put one tire in the air. Mark it and slowly rotate it one time around. Have another person under the rig counting how many revolutions of the driveshaft.
I don't have a tach, but I could rig up my shop tach for a test drive.
@pb4ugo " vacuum canister hose" do you mean the brake booster? That is the only thing on this truck connected to vacuum aside from the distributor.
