Thank you!what color code is this? looks great
No color code, mixed by a shop in VA. Based of Proffit Land Cruiser SEMA build.
Let me know if you want to purchase, I’ll share the paint shop information
I noticed that I couldn't do much with that same tire-iron. I needed the stepped-one that came with the tire-changer. The step allows you to push slightly (but you're not supposed to hammer) and pry at the same position. Also, it seemed like it was tricky in the direct sun of summer. My 215/75s are probably more narrow than what you were working with, so the bead kinda resists seating when mounting the second side.@Grayscale This job is a real pita. It took me 2 hours and all of the strength in my body to get this mounted…you have my respect
When I replace my rear cross member I plan to use rounded head bolts, which have a domed head with a female hex. You can get these in Class 10.9 and 12.9.Can someone settle an internal debate I am having…
I understand some owners go thru great pains to mimic the factory frame riveting when repairing or replacing frame components. Some will use carriage bolts to maintain frame flex and some will weld in new frame parts.
with the type of use the truck driven in, is it mostly acceptable for trails or paved roads using welded frame versus riveted frame for extreme rock crawling?
A simple screw-jack can be purchased, or fabricated from some correct length hardware (basically a bolt in compression, not tension). It presses the rivet in place between channel so that you can round-over the rivet with heat and a swage-block. A swage-block is nothing more than a dimple in a piece of steel, probably a drill-bit point is all that is necessary, and a handle. An acetylene torch, or carbon-arc-gouging electrode (for AGM/gel batteries or battery, or SMAW set-up) will provide the heat. It would be cake to mock-up a rivet-set-up to practice on some channel or box material. (I'm not speaking here from any frame-repair experience)Can someone settle an internal debate I am having…
I used this method when replacing the front frame member of my 45, then I had the frame galvanized. I don’t think it will come loose in my lifetime.When I replace my rear cross member I plan to use rounded head bolts, which have a domed head with a female hex. You can get these in Class 10.9 and 12.9.
Whoever came up with this little mod deserves a MUD Medal. $8 light from Autozone that popped into the hubcap and a little bit of wiring, and you have a third brake light. View attachment 3730714View attachment 3730715
That’s a pricey solder job…those Penny’s are worth money these daysThat's where I saw the 3rd eye first. The other day I watched a hot zinc dip frame done in England. If I ever get to that point I'm going to solder zinc pennies everywhere I can on the underside.
Thanks Al! It was hot dipped, quenched and painted.@Michael B …galvanized…wow! I don’t remember reading that in your rather excellent post coverage on that 45… I may have enthusiastically skimmed over it while digesting all of it….that was some hunk of work. Beautiful!!!
I had never seen the third brake light on a 40 mounted in the spare tire hub ever before. It’s such a great and useful add-on that I would be surprised if I was the first to ever think of it. But I love the added safety, and if I was the first to ever think it up, I suppose it should be referred to as the “Aloha Jen spare tire 3rd brake light” from now till the end of time…or at least till some else comes along and claims the idea before I had it in November of last year!I think it was @Aloha Jen. Credit where credits due…![]()
new shoes and finally back to the original wheels
I have the same wheels in silverish grey, did you paint those?
