The dirt in your state is a strange color.
Only 9 months of the year!The dirt in your state is a strange color.
I had the entire inside of my cruiser covered with that crap, it sucked.I hope to never have to grind bedliner off anything ever again.
Thankfully PO did a crap job applying it everywhere else. LolI had the entire inside of my cruiser covered with that crap, it sucked.
Double gross. Snow and grease.
Took trans cover from ashy to classy. Advance Adapters twin sticks conversion added.
View attachment 2984625View attachment 2984626
I hope to never have to grind bedliner off anything ever again. Holy hell that sucks and stinks.
Best not use a wrench anywhere in that vicinityPut one of those solenoid gizmos in between the batteries.
No, wiring is not my forte
yeah... what was that game??? Oh yeah... OPERATION!Best not use a wrench anywhere in that vicinity![]()
I figgered out very very quickly that one must be very very carefull with a wrench thereBest not use a wrench anywhere in that vicinity![]()
I have a similar problem... need to get some rubber caps for the four cap nuts on my new battery mounted platform:I figgered out very very quickly that one must be very very carefull with a wrench there
Got ‘er bolted in.Took trans cover from ashy to classy. Advance Adapters twin sticks conversion added.
Couple of wraps with the Super 88 and you're good to go!Best not use a wrench anywhere in that vicinity![]()
How long did it take for the to arrive after you ordered?Fj40dash.com upper and lower dash pads. Looks like i forgot to get a finished product photo after the lowers were installed. Really happy with how they fit and how they make the interior
feel complete.
Note, DO NOT use the supplied screws for attaching the dash clip panel, they are too long
I guess i was luck that only one screw poked through. You can see in that fourth photo there are bumps at each screw location, lucky that the material is so flexible/pliable, that probably saved me.
View attachment 2985191View attachment 2985193
Their website said out of stock, but i got it in less than a week. This is the second one i have bought and installed, very happy. On first one, i complained that the lower holes didnt line up. What i found on this second one is that you really should have top off and windshield down for proper install. I was able to get it to sit correctly and all holes line up nearly perfectly. I do have an issue with the small lower pad, seems they damaged all the threaded studs that secure the pad to the dash somehow and i cant get the nuts to install. Im sure they will sort it out and make it right for me.How long did it take for the to arrive after you ordered?
Thinking about ordering a set
