What have you done to your 200 Series this week?
New rubber. Decided to keep the 20’s. Bling bling. 275/60/r20 bfg
Here ya go , sir
Attached and tested Marine Corp surplus ruck, removed frame and attached with 2 straps. Highway tested. No issues.
I made the brackets at home with some mending plates from HomeDepot; I just had to enlarge one hole in each to make the Hella bracket bolt go through. I put only one per side at first, but there was some vibration from the light weight. I added two per side (one on top of the other) and it gave it more strength and eliminated the vibration. I got zinc plated mending plates, so hopefully they won't rust (@ $3 each). I wrapped the mending plates with some vinyl wrap I had left over from the grille so they matched the grille.
I attached the plates to two holes already there that hold the grille/bumper to front front support, just pop out the plastic push clip. I used a spacer (a tall, square washer type thing) between the plate and the top bumper support in order for the mending bracket to clear the bottom bumper/grille ledge and stick out front through the bottom-most grille opening. Just drive a long-enough bolt though everything and tighten it well. Using those two holes previously mentioned lets your lights be centered; no measuring.
Here's how they look. It took me about 10 minutes to install everything. I'm happy with the results and I spent almost no money doing this. Plus, everything is reversible if you don't like the look or what to switch light set up later. No drilling into the 200 :) Now I just need to wire them. I'm an ape when it comes to wiring/electronics, so I will have to read up on it. If anyone has any guidance, please help me. Thanks.
Added a puppy to the 200... meet Axel.
I installed Romer's well used ARB skid plates. Now if anyone looks under my LX they will think I go extreme too. Thanks @Romer.
Got the 2nd mount installed today so both CB and the Band-14 cell booster/radio-repeater and they both can fold down. Band-14 is FirstNet good for Hurricane Season, but I am at odds as it seems my Verizon signal is better overall.
Which RR is that?
